Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 06-17-2004, 01:28 PM   #1
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
A/C Cover Color
I presently have the one-piece cover of my original Bay Breeze air conditioner sitting in the shop, and decided, for UV protection, that it needs a coat of paint. What color?
Searching Airstreamphotos.com, most of the only Airstreams I saw with original air were missing a cover altogether. I saw one example where the cover may have been painted an aluminum color, but could not be sure. With that one exception, all the covers I saw were white in color, and they all appeared to be replacement units.
From a "reflecting the sun's heat" perspective, white & aluminum color would be fairly close. But when the A/C is running, reflection would seem to be a moot point with all the condensor fan air flow.
I recall a post on another topic where the poster said he "went retro" when he painted his cover an aluminum color. Did Airstream used to paint A/C covers an aluminum color? My cover could have very easily been painted, and all the paint wore off.
If nothing else, what do you think, big picture wise, of painting the A/C cover an aluminum color? It seems like a neat idea, but since I can just barely pick out my blue jeans in the morning, I thought I would ask for help.
Tom
Old 06-17-2004, 01:50 PM   #2
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Seems to me all of the old Bay Breeze units I've seen were either silver or extremely faded silver. If you could find a durable silver paint that would hold its color then I think that's the route I would take.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 06-17-2004, 03:09 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
You can paint them silver, but be sure to clearcoat it.
Or you can paint it white, so that the sun doesn't do it's thing on it.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-17-2004, 06:33 PM   #4
mtpalms
mtpalms's Avatar
Profile:  1971 23' Safari
Joshua Tree , California
Ours is silver on the bottom and white on top (POs, what were they thinking?). It is also past it's prime and is being replaced. I am inclined to go with white, because it would be difficult to match the silver of the cover to the trailer, especially if you've got a nice shiny one, or are planning on polishing it. Our trailer is kind of matte, as opposed to mirror finish, so it wouldn't look too bad I guess, and we could always paint over it. Darn! Something new obssess over!
mtpalms is offline   Reply With Quote
Old 06-17-2004, 07:34 PM   #5
Blackjack
Profile:  Beckley , West Virginia
MT, that is one beautiful photograph. Where were you? I think your matte finish looks great. David
Blackjack is offline   Reply With Quote
Old 06-17-2004, 09:14 PM   #6
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Tom,
I recently got a new A/C cover from InlandRV for my 1971. After fiddling with spray cans for a while, I decided to take it to an Autobody Shop and had it painted a metallic silver. They shot a coat of the metallic and then a clear coat on it. It looks great.
due to the dfferent shape and elevation, the match of silver color to the aluminum does not seem very crucial. I am very pleased of the outcome. i paid $$$ to get it done, but it's well worth it.
Uwe
Old 06-17-2004, 10:08 PM   #7
Happycampers
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
Argosy A/C
Hello.. My husband is going to paint the Argosy and we have thought about using Snow Roof on the top and was wondering about painting the A/C with it also.. Annie
Happycampers is offline   Reply With Quote
Old 06-18-2004, 10:07 AM   #8
mtpalms
mtpalms's Avatar
Creekside RV Park,
So. Fork Bishop Creek, 20 miles SW of Bishop, CA, 8500 ft above sea level
That picture was taken in mid May.
Old 06-18-2004, 11:35 AM   #9
pepper48
Profile:  1972 25' Tradewind
Rogers , Arkansas
My unit has the original cover and it is painted silver from the bottom up to the shoulder. The upper part is white. So far as I know this is the original paint scheme for 1972.
pepper48 is offline   Reply With Quote
Old 09-13-2004, 04:54 AM   #10
TomW
TomW's Avatar
Normal , Alabama
Images: 77
Mystery solved
Originally Posted by tcwilliams
... Did Airstream used to paint A/C covers an aluminum color? My cover could have very easily been painted, and all the paint wore off...
When I started this thread, in addition to paint, my shroud also needed either serious repair or replacement. The issue was dropped while other, higher priority items were addressed.
I am now revisiting the issue. A new shroud is available. I believe it would need to be painted, as the delivered price makes me think it must be made of solid gold. So, I have set out to repair mine.
Apparently, my shroud was painted silver at the factory because I found silver paint behind the air intake grilles. So, I think I will proceed with restoring it to it's original appearance.
While I have seen spray-can paint for plastic at Walmart, I would rather spray this with a gun due to it's size. Can anyone with painting experience advise me of what paint to ask for at a paint & body supply store that works well with ABS plastic?
Tom
Old 09-13-2004, 07:44 AM   #11
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
tom
when i have painted fiberglass motorcycle parts in the past, my local auto body supplied a two part (resin and hardener) primer made for fiberglass.
i used regular urethane with clear on top of that with good results.
if you cannot get good answers from paint supply places, perhaps find out what the boat guys use.
john
you call them ferrets, i call them weasels.
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 05:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 07:50 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 06:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 11:52 AM
Propane Bottle Cover Pahaska 2003 International 5 05-19-2003 10:53 AM
