Old 03-09-2011, 07:44 PM   #1
constructor's Avatar
1973 25' Tradewind
2018 26' Flying Cloud
New Smyrna Beach , Florida
'73 Tradewind missing trim at wheel
Where do we find missing trim?
Ann - The Constructor's scribe TAC FL-20
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
constructor is offline   Reply With Quote
Old 03-09-2011, 08:59 PM   #2
x
XXXX , XXXX
Ann google colaw's RV salvage or RV revive. The only place to get this trim is form salvage. It is not available from A/S. I am also missing some of the lower beltline trim but not the piece you need. BTW 74 and up is different.
wasagachris is offline   Reply With Quote
Old 03-10-2011, 07:42 PM   #3
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I'd have to check my notes to be sure, but I believe that specific trim is only found on '71 to '73. Later years used a plastic trim insert. IF you found some salvage from a later model trailer that was the same or larger, you could replace it all the way around to match.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 03-10-2011, 08:49 PM   #4
1973 25' Tradewind
I have started a new thread under the knowledge section title 73 Tradwind project and going to list our work there so I have everything documented on one thread. If you have time, check out our other trim question.
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
68 tradewind blue trim 4gentradwind Ribs, Skins & Rivets 0 05-11-2011 09:28 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Tow vehicle wheel base flynmike Tow Vehicles 15 05-09-2011 08:27 PM
Rub Rail aka Body Trim aka ??? ukinusa Ribs, Skins & Rivets 3 02-16-2011 05:42 PM
