Old 03-09-2010, 02:18 PM   #1
30 minutes to remove the big blue vinyl band
Apply parcel tape, pull it off with the vinyl attached, and put the coffee on the hob.
Nick.
ID:	97799   Click image for larger version
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 03-09-2010, 03:38 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I take it you're not going to put it back on?
Old 03-09-2010, 03:44 PM   #3
I'll be replacing the old vinyl decal with fresh new identical decal from my local Airstream dealer. The old stripe was showing its age.
Nick.
Old 03-09-2010, 04:26 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Neat tip Nick,
I will remember that myself.
Thanks!
Vaughan
Old 03-09-2010, 07:01 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Very cool. Nice tip.
Old 03-09-2010, 07:25 PM   #6
1988 34' Excella
Ovalo , Texas
Nick, thanks for the info. I also have an 34' 88 Excella. I am presently fixing the burn damage to the skin and this will come in very hand when I get to the strips.
Artb is offline   Reply With Quote
Old 03-09-2010, 08:01 PM   #7
I'm glad this is of interest. The original decal is wider than the gap between the top and bottom extrusions, so I presume the decal is applied and then the extrusions are riveted to slightly overlap the decal. I therefore scored along the decal with a sharp knife point running along each extrusion, so that the decal would peel away without having to tear away from under the extrusions. I used a very sharp kitchen knife to help the tape peeling when a section proved more difficult to lift off. Close attention to the peeling edge made sure that the peeling continued. Tomorrow I'll experiment with WD-40, paint stripper, citrus cleaner, and GooGone to see which is most efficient on my adhesive.
Nick.
Old 04-09-2010, 01:09 PM   #8
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Now that is helpful! I was just at JC and they said that you best plan on putting the decal back on because it will ALWAYS have a discoloration where the decal was.....
GREENovaters is offline   Reply With Quote
Old 04-21-2010, 05:16 PM   #9
James Rogers's Avatar
1987 34.5' Airstream 345
Dandridge , Tennessee
How would this method work on a 1976 GMC Palm Beach motor home? The stripe is old and faded. I've tried heat and a razor but that didn't work real good. This moho sat in the sun for a long time before I bought it. The paint is faded and bleached out. I want to repaint it but I have to get the stripe off first.
James Rogers is offline   Reply With Quote
Old 04-22-2010, 12:15 AM   #10
Why not try a patch and let us all know? Find the stickiest parcel or other tape that you can find. I used the cheapest nastiest stickiest ordinary brown tape for parcels that I already had in our trailer "bits and bobs" drawer. You've presumably caused some damage by heating and scraping, so I would try near that area.
Nick.
Old 04-22-2010, 12:20 AM   #11
Aluminum in 3-D
Blue Pearl's Avatar
1968 28' Ambassador
Seaside , Oregon
I'm going to try it tomorrow, thanks.
Teresa
Membership chair
Wally Byam Airstream Club
Past President Oregon Unit 090
Campfires, the original social media!
wbcci#29827
Check out the [URL="https://airstreamclub.org/"and Wally Byam Airstream Club on facebook
Blue Pearl is offline   Reply With Quote
Old 04-22-2010, 07:05 PM   #12
1981 31' Excella II
Longview , Texas
Images: 14
The decal on my '81 Excella II seems to be 'baked' on. Not sure this will work but I'm gonna give it a try. I'm obviously damaging and scratching by using a stripping wheel. So -- just put the tape on and pull it off? Sounds too easy.
boo_n_sue is offline   Reply With Quote
Old 04-22-2010, 09:17 PM   #13
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
3M makes an eraser wheel that goes on a drill to remove decals. It won't harm paint. Auto body shops use them. You can go to the 3M site and see it, plus there are several videos on Youtube demonstrating the way it works. Might be just the thing and it won't harm the skin.
Old 04-22-2010, 10:12 PM   #14
Great tip nick.
We were stripping the clearcoat on ours while removing the stripes so just used the paint stripper (Glasco). I worked great on the stripes but took 3 coats due to there being 3 sets of stripes, one on top of the next, on ours. Blue, then red, then blue again?!? We did what we could to remove the adhesive but it seems to be embedded into the aluminum after 30 years. Polishing works well but needs more man hours than I was willing to put into it last summer to get it all gone.
You can see the residue that the polish didn't remove in a few compound runs below. It isn't sticky residue but more like sandblasted feel:
What's under the wide blue band? JimGolden Clearcoat, Exterior Paint & Trim 20 06-07-2009 07:27 PM
Big Band Swing snog Off Topic Forum 13 05-23-2009 06:46 PM
Blue Vinyl Insert davidz71 Clearcoat, Exterior Paint & Trim 0 09-12-2004 07:07 PM
vinyl blue trim strip t&m Clearcoat, Exterior Paint & Trim 6 07-30-2004 10:21 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
