Old 07-15-2011, 10:03 PM   #1
1984 31' International
Lincolnton , North Carolina
Question 2 replace decal or not to replace?
How hard is it to remove decal and what should I use? Where is the best source for decals and the blue slide in trim? Does decal replacement lower 'vintage' value?
Thanks in advance!
nustreamer is offline   Reply With Quote
Old 07-15-2011, 10:28 PM   #2
1985 31' Excella
Fresno , Texas
If its cracked bad you can use a pin stripe eraser wheel. Sometimes you can heat it with a heat gun and peal it off. The cost is close to $4.00 FT. The other slide in is called the belt trim. You can get it from Airstream dealer, Vintage RV. or Out of doors Mart.
Wsmith is offline   Reply With Quote
How to replace a Stack window glass. montanablue Windows & Screens 18 07-13-2019 06:24 PM
Hard To Replace Sony In '06 Bambi? jambie Audio, Video & TV 19 08-24-2012 12:18 PM
New Decal for her funkill Clearcoat, Exterior Paint & Trim 8 04-07-2011 07:58 AM
To replace the pump or not? MTsafari Water Heaters, Filters & Pumps 8 04-04-2011 07:20 AM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
