Go Back   Airstream Forums > Airstream Community Forums > Our Community > Fun & Games
Closed Thread
Old 01-12-2012, 10:51 AM   #321
Retired.
. , At Large
Originally Posted by worldinchaos View Post
I'm just glad we haven't fully started discussing our rubber rods wearing out and about which replacement is best for our TT's to ride on.
Btw back to hitches, it seems that the average is 2" balls. Who's got bigger? I wanted to swap mine out but my female receiver is too small. It was probably made in Japan.
You do know that if you own a later model Airstream you need a bigger ball?
Gawd, i've waited YEARS to use that line!!!
overlander63 is offline
Old 01-12-2012, 11:26 AM   #322
Didnt read thru the whole thread yet, but does anyone have an opinion on if its better to have the Levelers down for stability, or leave them up for the "cushioning" effect??
On my 345 motorhome, the whole bedroom hangs out a long way behind the rear axle.... Not tested it yet, but inquiring minds need to know!
Keyair is offline
Old 01-12-2012, 11:31 AM   #323
whitsend's Avatar
1954 25' Cruiser
Kyle , The Republic of Texas
Originally Posted by zigzagguzzi View Post
Been on the forums probably longer than you for whatever that is worth. This kind of humor? this stuff is funny
Ziggie - If such innocuous humor upsets you, if you can't see the connection to Airstreams and Airstreaming folks, why don't you just hit the ignore key and quit putting yourself on that slippery 'high ground' claiming you didn't / don't open the thread?
I love that old time rock & roll.
whitsend is offline
Old 01-12-2012, 11:36 AM   #324
Air-Texas's Avatar
2004 34' Classic S/O
Stafford , Virginia
So, if I am reading this right, you are proclaiming to the world that you have a small ball!
your AS is a 74? I have a 2004!! I win!
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline
Old 01-12-2012, 11:39 AM   #325
Hampton , Virginia
Ball size...
So are you saying if you own a later model you talk like Leon Redbone sings, and if you own an older one you sound like you have been breathing helium?
Getaways is offline
Old 01-12-2012, 11:40 AM   #326
Air-Texas's Avatar
Stafford , Virginia
answer
1. I need to run some tests, just to be sure.....
2. change of pace is always good
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
Old 01-12-2012, 11:45 AM   #327
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
My understanding is that you may have to replace your axles for the appropriate lift over the wheel wells. Axles with the arm at a downward angle indicate they are old and need to be replaced, as they may be too stiff for comfortable ride. That may be also be applicable to the amount of flex if the trailer is in a stable / parked position. Not sure if that would apply to a MH though. Your axles are completely different, and connected to a drivetrain. I would expect that bad shocks in a trailer or MH that uses springs could produce an uncontrolled bouncing effect on uneven terrain - but could not evaluate that if the vehicle were parked. I guess the greater weight in a MH would require a higher force of momentum based on the mass of the MH compared to a light trailer. Meaning, with bad shocks and good springs, you could bounce a trailer much easier than a MH. Maybe try jumping jacks in the back and see how bad it gets?
robwok is offline
Old 01-12-2012, 11:58 AM   #328
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Oscillating vibration is always about (frequency x force). I am not an engineer so I can't put numbers to the formula but any extended protrusions will accentuate the deflection.
masseyfarm is offline
Old 01-12-2012, 12:18 PM   #329
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Inquiring Mind Here
Don't own a motorhome, but I think it is dependant upon the energy of the "driver." If you leave the levelers up, you might be able to pump once....then coast for two.
Fly at Night is offline
Old 01-12-2012, 12:19 PM   #330
zlee's Avatar
2008 19' Safari SE
Denver , Colorado
Ooo er, missus!
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline
Old 01-12-2012, 12:20 PM   #331
zlee's Avatar
2008 19' Safari SE
Denver , Colorado
I've had BFs who tried to run the entire relationship like that.
zlee is offline
Old 01-12-2012, 12:27 PM   #332
Love those Texans! You tell it like it is.
I tried to be nice. It's a Canadian thing.
Oh, I am giving him the benefit of the doubt. Maybe he accidentally dropped his "hitch" on the keyboard.
Old 01-12-2012, 12:34 PM   #333
r carl's Avatar
Lin , Ne
Sometimes you need the bigger 2 5/16 ball.
r carl is offline
Old 01-12-2012, 12:48 PM   #334
rgesch's Avatar
1956 26' Cruiser/Overlander
1967 17' Caravel
Newport , New Hampshire
Images: 18
Why is it that the mods let these goofy threads go on forever, yet they close firearm/second amendment threads at the drop of a hat?
KB1UFH
KB1UFI
"Reality Is The Leading Cause Of Stress"
"There are only five great men in the world and three of them are hamburgers."
rgesch is offline
Old 01-12-2012, 01:03 PM   #335
Steelegood's Avatar
2005 31' Classic
Cleveland , Tennessee
Fly by night, that may be possible, but not at a forum rally where booze is number one. Just check any rally thread. jim
Hey Jim (zigzagguzzi):
When we joined the Airstream Community, we felt like complete outsiders, but the unit we joined welcomed us with open arms. Most of our members are in their 70's and beyond. However the information I/we've garnered over the years far exceeds (someone's) their perceived perversions. I really hate it for you that you are basing your opinion on a few threads, and have never really enjoyed the true benefits of belonging to a group who have something in common (Airstreams) or attended a few rallies (we've spent endless nights sitting around a table playing a somewhat popular game among 'streamers - Jokers, no ETOH involved)! In fact my knowledge base has been increased more than tenfold relative to upkeep, maintaining, etc on the trailer. This "perverted" thread as you view it, is just an outlet for pent up frustrations, and most if not all is just stated in jest and, with the winter months, and not being able to go out and enjoy your Airstream, most adults have accepted the fact that intercourse (look up the actual definition) in this nature is natural. As others have suggested, either ignore the thread, or get out there, get involved, and accept the fact that not everyone is afraid to voice their concerns or opinions, and if all this offends you...., then maybe you need to expand your knowledge in the carnal sense or realize they are just amusing euphemisms, to understand all that has been stated is just to humor each other. Perhaps it is b/c I am in the medical profession, but I've raised my children that all is natural, and open for discussion, including but not limited to unwanted pregnancy, drug abuse, prevention etc. Putting a light twist on it, well it just lightens the situation. Go out and enjoy yourself, your Airstream, and embrace the knowledge and friends you meet along the way.
Terry.
I know you think you understand what you though I said, but I'm not sure that what you heard is what I actually meant!
"If you don't know where you are going, any road will take you there." Lewis Carroll
AIR #38011
TAC TN-4
NOVA
Steelegood is offline
Old 01-12-2012, 01:03 PM   #336
Southwestern , Ohio
Because the gun threads make people angry while this thread makes people laugh.
Nuvite-F is offline
Old 01-12-2012, 01:13 PM   #337
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Maybe because goofy is harmless.....?
Steve; also known as Mr UK Toad
"You can't tow that with that!"
https://sites.google.com/view/towedhaul/home
MrUKToad is offline
Old 01-12-2012, 01:13 PM   #338
MrUKToad's Avatar
Chatham , Ontario
Oh for a "Like" button
MrUKToad is offline
Old 01-12-2012, 01:16 PM   #339
MrUKToad's Avatar
Chatham , Ontario
But only one, eh?
MrUKToad is offline
Old 01-12-2012, 02:11 PM   #340
zlee's Avatar
2008 19' Safari SE
Denver , Colorado
Then it's the keyboard that needs the mild bleach bath!
zlee is offline
Closed Thread
Airstream MH for FT? kb0zke Land Yacht/Legacy Motorhomes 13 10-23-2016 07:28 AM
