Old 11-28-2017, 01:07 PM   #1
2018 25' Flying Cloud
St James , New York
Stabilize bars
My 2018 flyingcloud , my question is when backing in a campsite , should I remove the swaebar bar from my hitch making easy to back in. I was told it is easy with them off. To anybody that wants to answer.
Tiffin is offline   Reply With Quote
Old 11-28-2017, 01:13 PM   #2
Gainesville , Florida
Depends on the hitch. Ive never taken mine off.
Old 11-28-2017, 01:39 PM   #3
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
What brand of weight distribution and sway control do you have?
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 11-28-2017, 01:48 PM   #4
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I remove the two Husky anti-sway units from my Eaz-Lift hitch, but leave the WD bars engaged to avoid bottoming out the jack foot if there is a dip in the ground to be negotiated. I usually do this when checking in at the campground to eliminate them ‘groaning’ during low speed turns.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 11-28-2017, 04:01 PM   #5
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
As stated above. Also depends on the angle and the transition grade. Straight, not much issue. Tight turn can be a problem. More so for clones than the primary brands, but in any case, get out and look at how much clearance you have. A severe bump or ditch can be a significant problem on a stiff hitch. The friction sway struts can be problematic as well.
Read your manual. Read the threads on your hitch. Experiment carefully a bit. You will figure it out. Note, if it's a problem to back up it's likely a problem in a driveway or tight turn too. Try before it's an issue on the road. Pat
Old 11-28-2017, 04:06 PM   #6
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I have always left my Blue Ox sway bars on while parking, but few times the tension was pretty tight. Could have removed while level, and likely had easier time of it. I have also left them "off" when hooking up, in tight situations, a few times and installed when I got to level ground. Only takes a few minuets to install when you are also using a 6x6 block and adjustment on your jack foot, if needed.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 11-28-2017, 04:58 PM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Equalizer hitch you can leave them on no problem.
wulfraat is offline   Reply With Quote
Old 11-28-2017, 05:02 PM   #8
2007 22' International CCD
ProPride or Hensley has no anti-sway bits and pieces to remove--just back up normally, and they work just fine...
Have had to slack off on weight distribution in the occasional tough spot..
Old 11-28-2017, 05:05 PM   #9
Mollysdad's Avatar
I have an Equal-I-zer and I haven't taken mine off but I've heard about it. I think the only gain is to reduce the creaking noise that sounds like your frame is cracking. That's normal at parking lot speed.
The downside is now the tow vehicle is now sagging at the rear, your headlights are in the trees, your mirrors are looking at the ground, and you could drag the shank much easier.
Old 11-28-2017, 05:29 PM   #10
2018 27' Flying Cloud
I think this depends on what tow vehicle you have, what model Airstream you have more than anything else. I, like you, have the Equalizer stabilizer, but with a ¾ ton pickup, I don't have that problem even with the 27FB when I take the bars off and tow. In fact, I debated heavily about even installing the stabilizer kit, but figured it didn't hurt.
-Wayne
wbrisett is offline   Reply With Quote
Old 01-28-2018, 08:42 PM   #11
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
Most friction sway control bars should be removed when backing. That fact convinced me to go with a system which did not use friction, and we settled on a Hensley system. No regrets since.
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 01-28-2018, 09:05 PM   #12
Johnnyooo's Avatar
2016 16' Sport
Colrain , Massachusetts
If it's a friction anti sway control, tight turning while backing up puts stress on the sway bar. I remove mine when backing into campsites....
Johnnyooo is offline   Reply With Quote
Old 01-29-2018, 05:28 AM   #13
I used friction antisway bars for years and never had any problems backing up. I used one and sometimes two, never a problem. Distance from ball to frame mount must set up accirding to instructions. Too short will not work.
Old 01-29-2018, 08:07 AM   #14
2012 28' International
Prince Edward County , Ontario
We have the same set up and do likewise although we sometimes just loosen the anti-sway bars.
Cyclist is offline   Reply With Quote
stabilize roof for fan? MAJORJDB Roof Vents, Skylights & Fans 11 06-25-2017 01:16 PM
Hensley 1,000 lb bars or 1,400 lb bars? Herm26U Towing, Tow Vehicles & Hitches 7 12-29-2016 10:53 AM
Best way to level & stabilize a '60 glw73069 Jacks, Stabilizers, Lifting and Leveling 4 07-15-2015 02:23 PM
Pipe Frame stabilize/reinforcement Vintage One Repairing/Replacing Floor &/or Frame 1 07-05-2010 01:54 PM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 07:58 AM
