Go Back   Airstream Forums > Airstream Community Forums > The Rally Zone
Old 05-07-2003, 12:20 AM   #1
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Dump station follies
We attended the Region 8 rally last week in Columbia Mo. at the county fair grounds. There were 100+ units there and all of us departing made the mad dash for the two hole dump station during a break in the torential rain and storms that were hitting the state on Sunday.
Both dump stations were occupied so I lined up behind a small vintage unit on the right. The station on the left was occupied by a Cutter motorhome. The owner of the Cutter was extending his levelers up and down quickly and the motor home looked like one of those low riders you see in L.A. where the kids jump their cars at the traffic lights. Apparently his black water tank was full and when he opened the valve nothing came out. He ended up giving up after 15 minutes of effort.
The guy in the vintage in front of me connects his hose to the vertical fitting and pulls the tank valve lever. Instantly as the hose fills it comes off the fitting. He attempts to pick up the hose and hold it up to the fitting as the sewage pours over his hands. He gets it shut off, looks at it for a few minutes and calls his wife.
She gets out and he holds the hose up to the fitting, she opens the valve and they finish the dump.
Unfortunately there is no water hose at the dump water faucet to help rinse the debris. He lifts the faucet valve with his contaminated hands and rinses his dump hose (allowing what ever was left in the hose to dump everywhere but in the sewer. He then rinses his hands and arms and moves on. Thankfully most of the waste did get into the sewer and I thankfully slip on a set of disposable plastic gloves that my wife supplied for just these situations.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 05-07-2003, 12:43 AM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Yuck
Jack
Smart thinking on your wife's part.
ciao
AIR 807
53flyingcloud is offline   Reply With Quote
Old 05-07-2003, 07:08 AM   #3
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
I was at Flying J getting gas and LP when a bus driver parks and wanders over looking at the dump station. He was upset that Flying J installed concrete poles around the dump station. Inquiring farther I asked, what side is the dump pipes on? He said the right side. I asked, your sewer hose won't reach? He replied:
Oh, I don't use a hose, I just swing the back over it and pull the lever. Since the sewer pipe is down in that concrete square, everything goes down the pipe.
Now I know what IDIOT is making a mess at the dump station and why Flying J smartly put up the concrete barriers!
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 05-07-2003, 11:37 AM   #4
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
This is the part I am least looking forward to learning about. Is there anything tricky to it, or was the guy who made the huge mess just unlucky to have his hose pop out? Should he have been holding it in while someone else pulled the valve? Sounds like rubber gloves are going on my shopping list.
My trailer is empty now so I ran a bunch of water into the toilet and pulled the valve so I would know how it worked (we're on our own acreage, so that little bit of foul water wouldn't bother anyone - much less mess than the time the septic guy powerwashed our septic pump on the lawn- yuk) but I'm still nervous about the first time we take it camping and we have to use a dump station (only one week away now)!
Stephanie
Our family photo blog
Old 05-07-2003, 11:47 AM   #5
femuse
Profile:
One of my favorite story is when Mike dropped the hose in the dump hole.
I was not going to leave it there. My civil duty - it was blocking the opening..... and
.... the fact that it was brand new & expensive.
It took me over 5 minutes of fishing with tree sticks. but I got it out.
femuse is offline   Reply With Quote
Old 05-07-2003, 11:55 AM   #6
53flyingcloud
Unhappy Unexpected 'guest'
I'm not sure where I read it but, the story goes...
The lady of the house was having guest over for a 'Garden Lawn Dinner' party and, just before the guest were to arrive...She went out to pull the valve on their A/S so that the guest could use it if needed be..
As it was reported, a raccon had chewed holes all over their hose.
You can the rest...
ciao
AIR 807
Old 05-07-2003, 12:37 PM   #7
1985air345
1985air345's Avatar
Stephanie,
A bad dumping experience is high on my list of fears! If you use that fear to your advantage, you should not have any trouble. Take your time and be careful. Make sure all the fittings are on tight. Since you dump the black water (toilet) and then the gray (wash water), the hose is usually fairly clean.
I typically run a bunch of water into the black and gray to help the process. It's always better to dump a mostly full tank.
I have a large stash of disposal gloves.
I usually hold the universal fitting down to the pipe just to be sure! ACTION CURES FEAR!
Fred H.
Old 05-07-2003, 12:41 PM   #8
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I used to have only one Thetford coupler. I would switch it between the Blue Tank and sewer hose at state parks. Well, the first time I tried it, I did not tighten the hose clamp enough. You can guess what happened when I pulled the dump valve.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 05-07-2003, 01:53 PM   #9
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Your hose is secured to a plastic fitting (coupler) which connects to the outlet on the trailer. The dump hose is secured to the coupler by a hose clamp similiar to ones used on automobile radiator water hoses. Those clamps can get loose and in his case once the sewage hit the hose, the weight of the water and other stuff pulled the hose from its coupler. The coupler is securily attached to the outlet on the trailer by a twist type of lock. Now if you don't twist properly when you connect you can blow the coupler off once the water hits. I've seen this happen also.
This is just one of those maintenance items that you need to occasionally check. He learned the hard way.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 05-07-2003, 02:01 PM   #10
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
One other thought. For the 18 years I have owned different brands of travel trailers, all of which were configured with the black water handle being closest to the bumper. The grey was the one closest to the axle. My Safari is reverse of that which I assume is the same for all A/S units.
I know I have to make a concentrated effort to watch which handle I pull. Be careful here if you have had a SOB in the past.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 05-07-2003, 02:14 PM   #11
Dr. Harold Becker
Profile:
<<This is the part I am least looking forward to learning about.>>
I found this site on another Airstream thread. I went out and bought it straightaway. It was expensive but extremely well made and it appears that it will likely last for many years.
http://www.sewersolution.com/index.htm
Do a search here to see what others said about it.
Good Luck
Harold Becker
Dr. Harold Becker is offline   Reply With Quote
Old 05-07-2003, 02:37 PM   #12
Astrodokk
Astrodokk's Avatar
Profile:  Santa Rosa , California
When I was in the Army, we dug catholes. Nothin like bein in nature!
When we were in populated areas, we'd just stop and use restrooms. The locals never seemed to mind the invasion.
I know, I know, can't do that all the time. I figure I'll teach my kids how to empty if they wanna go out in RV's.
Glove Club sells latex gloves at $2.95 per box of 100 gloves (50 pair). In dentistry, we need alot of them.
1981 Excella 454 28', rear bath, twin beds.
Astrodokk is offline   Reply With Quote
Old 05-07-2003, 02:42 PM   #13
53flyingcloud
Question Connection size?
Dr Harold Becker
Thanks for that insight and link. It just may be the answer to the problem. It's true, no one likes to use those old 3' slinky hose~!
My only concern is one of the fitting used to connect the drain valve.
If I may, several years ago when I first picked up my unit, it was decided early on to replace the old hose with a new one..Little did I realize then, not all fittings for drain valves out there are the same size. The one used on the SOB's are smaller in diameter.
It seems that A/S uses one that is so far removed the norm. It's just ever so slightly larger`!
You said you bought one and, I take it that, you are using it on a A/S trailer?
I'll be sure to check back for your answer on that point before I order one.
BTW, Were you ever at MGH in Boston? My oldest son was involved in a horrific auto accident in the late 80's and, the surgeon's name then was Dr Becker as well.
I could never thank that Dr. enough for saving our son's life.
ciao
AIR 807
Old 05-07-2003, 04:08 PM   #14
Stefrobrts
Stefrobrts's Avatar
Wow, that sewage device sounds pretty neat. One thing I'm wondering about is that I don't have a grey water tank, so I bought a blue tote to use with the trailer. This first rally we're going to has 'full hookups', so I assume that means I just hookup the slinky hose to the trailer and to the dump hole on the site, and let the grey water run right into it. I won't even need the blue tote this time, as I understand it. However, since I don't have a grey water tank, when it's time to go I pull the black water valve, and then what, run some more water into the toilet to help flush it all out from above?
I wonder if that sewer solution can be left hooked up without water running to it to drain grey water for those of us who don't have grey water tanks?
Never spent so much time thinking about sewage :-)
Stephanie
**Little Boo Boo's** Silvertwinky On The Road... 22 06-05-2007 09:49 PM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 03:31 PM
Dump Valve Leak David Hall Waste Systems, Tanks & Totes 8 02-17-2004 06:26 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 09:25 PM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 07:40 PM
test
Airstream Forums -
