Old 02-24-2004, 07:50 AM   #1
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Question Window Stone Guard What to do?
As mentioned we have a few things to do but nothing really major like a complete tear down of the interior or replacing all the outer skin
However....Our Window Stone Guard has seen better days. It must have taken a good blow to the arm which shot right through the panel (compound fracture - ouch!) - Must have travelled through quite a few Texas Dust Devils - as she is sporting a flying nun look on either side too.
I would much prefer the nice smoked Plexi? material. And it would be great if we can use the same frame.....
Questions:
1.Has anyone removed and reinstalled using the same frame? - Can you share instructions?
2.What is the best way to remove the riveted "Piano Hinge" from the Outside or Inside? Also never played with rivets before - what is the best drill out technique to use taking into consideration the replacement rivets.
3.Does anyone know where to get the Smoked Plexi material?
4. Can you still get the lifter arms and/or hardware? used on the '69's
For ever in need...and for ever grateful for any assistance.
SPK
GT1963 is offline   Reply With Quote
Old 02-24-2004, 08:19 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The Rock Guards are still available from Airstream. They come complete.
Check my photos, I recently put one on my 1971.
The old one removes by drilling out the rivets with a #30 drill bit.
Andy at Inlandrv.com has drill bit kits for all sizes of rivets normally used on Airstreams. The new RockGuard comes with mounting hardware. Mine came with Stainless screws to attach the top hinge.
Uwe
www.area63productions.com
Old 02-24-2004, 08:57 AM   #3
fritzs's Avatar
Window stone guard
I have the same problem with ours on a 69 Sovereign. Ace Fogdall didn't have them in stock this Spring, but would order one in for me at $499.00 plus freight for the dark colored unit. (Jan 2004) Here's my reply. Any other ideas? Do the newer dark colored units hold up better than the older clear plastic units?
(Fritz-
We would have to order the solar grey rockguard, the cost of which is
$499.00 plus truck freight. Thanks.
Florence & Kristy
Ace Fogdall RV
Parts Dept.)
69 Sovereign 31 Int'l
2004 F-150 4WD 5.4L Triton
Spaniels, kayaks, biking,cross-country.
fritzs@usfamily.net
fritzs is offline   Reply With Quote
Old 02-24-2004, 09:14 AM   #4
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Inland RV has some nifty looking shields. Part #34943.
$350 + shipping. The pic is from their website.
Rog
Rog0525 is offline   Reply With Quote
Old 02-24-2004, 09:32 AM   #5
tinman7's Avatar
1976 27' Overlander
St James City , Florida
Images: 13
I have wondered if I needed one for my 76 overlander. It dosn't appear to have ever had one. I haven't had it out on the road yet but hope to this spring(purchased last oct.) when I finish all the repairs. I guess I'm asking should I get one?
Love this site,Learned so much haven't had to ask any questions till now.
Frank
tinman7 is offline   Reply With Quote
Old 02-24-2004, 09:53 AM   #6
Rog0525's Avatar
Images: 11
Tinman, the rock guards have several purposes. Window protection of course, but also serve as an awning and provide UV protection. They also look pretty snazzy IMHO.
Since they have to be shipped by truck the shipping cost is high, maybe a hundred bucks or so.
The guard on my Caravel is the older flimsy plexiglass and has a couple cracks which can't be patched. Guess I'll be shopping for a new one soon.
If you don't mind parting with the cash, I'd recommend getting one.
Rog
Old 02-24-2004, 10:27 AM   #7
Buckhorn , Ontario
Images: 59
Wow - what do you guys think we are millionairs!
I thought people who bought the vintage A/S were frugle in their hunts!
I called Airstream and they say I have to go through a Dealer - so they were kind enough to give me 3 in BC only 3000 miles away
Anyway got a number for one in NewYork - Holiday on Wheels and of course the one in London Ontario - which You may as well be ordering Gold Bullion. $468 US last years price - add about 10% the gentleman said. So I could just imagine what Can Am would charge - YIKES
So back to the drawing board......and this is what my local research turned up...
The material used is a Lexan - Airstream uses a slightly cheaper material but for us layman it is basically the same stuff.
So I hunted for just the material as our old frame other than a bit of stress at the ends where the piano hinge finishes is just fine.
For a 4X8 sheet it is about $280 CND no - tint - waiting on a price for smoked. (Also got a price on 24 gage Aluminum $45 a sheet- for some inside finishes we are looking at - like kick plates at the bottom of the cupboards - will stop the veneer from pealing off - and picks up on what they do in many "water Yachts").
But the gentleman was real nice and said if you want to save even more money go to Trent Glass (Here in Peterborough) and wow guess what?
Material with tint/smoked, cut/shape and poprivet back into place (along with a bit of re-pressing of the frame in our case) she will cost a grand total of about $175CND = $140US.
For those who do not have a frame - I contacted a place here called Bruce Fabricating and they will make one based on the dimensions supplied. Only about 1-2 hours work at $55/hour and the u-channel type crimped aluminum edging is not very much either.
So how is that for a Newbie From a price of about $600CND to $175
Looking at Lee Valley for some hardware - not sure if you have them in the States - check out their web site hardware section might find some handy things[URL=http://www.leevalley.com[/URL]
When we get the Guard done we will certainly post some pictures.
If it looks and works great then we just might start our own little business and offer personal delivery - for extended holidays
SPK
Old 02-24-2004, 02:28 PM   #8
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Thumbs up GREAT IDEA
Sharon.. Great idea.. let me know how you make out.. we were going to spring for one next winter if we went to Calif .. but would rather keep the business here.. I can forsee a business opportunity for you here.. Annie
Happycampers is offline   Reply With Quote
Old 02-24-2004, 02:41 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Andy's price on the original Airstream Rockguard seemed fair to me. Once installed, it contours very well, has a sealing lip to keep debris out from the front window area, and definitely looks like it belongs. Remember, you often get what you pay for. Much more than just a piece of Lexan. Although, if it is only Rock protection you want, aside from aestetics, then the other way would do the job just fine, I imagine.
Uwe
Old 02-24-2004, 03:23 PM   #10
Rog0525's Avatar
Images: 11
Apples and oranges
GT6921, when I bought my 'new' 1971 Caravel last July I also thought of just repacing the cracked "plastic" in the existing frame and I ran the idea up the flagpole here.
The thread is at http://www.airforums.com/forum...ight=rockguard
Note in particular the reply from Inland Andy where he advises that the construction of the new style is far superior to the original.
I doubt that anyone is going to tell you that your idea won't work, but comparing the cost of replacing the lexan in the original frame to the price of a totally new unit is kinda like comparing an apple to an orange.
If you do proceed with your idea, I'll be curious to know the result.
Good luck, pilgrim.
Rog
Old 02-24-2004, 04:09 PM   #11
jaco's Avatar
Cool Go Slow / Be Happy
My two cents and thats an overstatement!
Unless you are going to a fire or have a deadline to go to the prom I would remove the thing for now. (You can buy #30 drill bits closer than California). A #30 is between a 1/8th and a 9/64th. Any of the three will do but go with the #30 if your hardware man has them.
Buy a good awl or pin punch and mark/indent the center of the rivet heads carefully. You gotta drill as close to perpindicular as you can. You are trying to go thru the dome head and down the shaft as near straight as you can without wollowing out the hole much.
It is a real pain in the arse. But you get the hang of it soon enough. Be patient let the drill do the work. Don't burn yourself as there is gonna be some heat genned from friction.
Buy 4 or 5 drill bits as you never will have enough and you'll dull and break a few.
This will give you some needed practice on removing rivets.
but as the front is a high profile area you want to learn real fast and real slow if you get my drift.
Before you remove it take alot of pix. From ever imaginable angle and showing all conectors and hardware.
After you get the thing off store it. I might be interested in it but doubt the shipping would compute.
Fill the rivet holes with pookey. You can even add rivets to the holes if you feel like it will be a while before you replace.
Get busy with the other 120 or so things you will come across.
Research different stone guards and when ready order and put it on.
Some where in my hours of surfing the mazes of Airstream and RV sites I recall some fella had a write-up on making your own rock guards from scratch. You'll have to find it yourself, maybe someone here can recall where it is.
Start looking for a Stanley #?77?? swivel headed hand riveter tool.
Hard to find but highly recommended.( I can't locate one in the 4th largest slum in the USA. However there is a tacouria on every corner and voo-doo herb stores on every block...viva Texico !)
Oh might as well get familliar with rivets and order some (100) Olympics from somewhere. A guy on this forum has a great price.
68 Overlander in Alabama he is. Look him up. He also sells convertors or invertors or pervertors or some kinda erters.. maybe even frankferters.....
Now if you got a neighbor kid with a sling shot you might revise this schedule.
jaco is offline   Reply With Quote
Old 02-24-2004, 04:16 PM   #12
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Just a note to all who care.
This weekend I installed a three piece Rockguard on a Argosy Minuet. It took me about 5 hours including disassembly of the center section, cutting it and rebuilding it.
I will be posting a detailed "How To" on this job.
As for full size trailers, I don't see why can't replace the Plexiglass if needed. A drill and a few pop rivets would be all that is required for the job.
I would be a little hesitant to build one, this is because of one detail on the factory unit.
The factory extrusion has a place to attach a molding strip which seals the window glass all the way around the guard.
It appears to me if you are going to build it you must figure how you are going to seal it. It is necessary to keep rocks and debris from getting in around the edges if you want to keep your windows intact.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 02-24-2004, 04:30 PM   #13
Rog0525's Avatar
Images: 11
Re: Go Slow / Be Happy
Does that come from California too? Do you know the part number?
Rog
Old 02-24-2004, 04:50 PM   #14
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Pookey - You guys crack me up!
SPK, good for you guys. I can't wait to see how it goes. I have a front window guard that has taken it's share of rocks over the years, and I've been playing with the idea of replacing it with tinted lexan. I'll be interested to see how yours goes.
Also, Lee Valley rocks. I've never seen so much cool stuff in one catalog.
Stephanie
