Old 08-18-2010, 04:21 AM   #1
1989 32' Excella
Benson , North Carolina
Window removel.
Hi all again. I am having trouble removeing the rear window on my 1998 Excela. I read the book and it looks easy, but it will not slide up and out. What am I doing wrong?
elzavb is offline   Reply With Quote
Old 08-18-2010, 04:26 AM   #2
Lift the bottom of the window so that it's far above the hinge, almost 180 degrees, if you wish.
The window should then just drop out of the hinge setup.
How to clean and paint wood walls AFTER wallpaper removel whitefawn Upholstery, Blinds, Walls & Interior Finishes 2 07-21-2010 07:52 PM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 06:52 AM
Dent removel - two methods j54mark Ribs, Skins & Rivets 13 04-18-2003 11:52 AM
