Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 07-23-2008, 07:43 AM   #1
pyanke's Avatar
Profile:  1985 25' Sovereign
St Cloud , Minnesota
Window Guard Gasket Position
I have been having a leakage problem in the front of my 85 Sovereign any time we get excessive rain. Investigation brought me to the front window guards. The gaskets on the wing pieces have a gap at the bottom of the window and are dry. The center window guard has a wide gap in the gasket at the top near the hinge . There is no gap in the gasket at the bottom of the window. I am thinking that the window actually fills up with water and then leaks into the trailer.
Any info would be helpful. Thanks.
Pete
WBCCI #7528
1st VP MN Unit
pyanke is offline   Reply With Quote
Old 07-23-2008, 08:00 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Can you adjust the top rock guard inward at the top? I would also check the clearance lights above the window, you have three holes per light that can leak water. Failing everything else, you can always take a razor blade, and cut a small gap in the gasket at the bottom of the rock guard for the excess rain water to drain out of. You may have a bad window gasket along with everything else. Can you use a garden hos and assistant? Have the assistant spray the window area, starting at the bottom, and watch from inside until you see water.
(No Longer at Inland RV)
Old 07-23-2008, 09:55 AM   #3
Commercial Vendor
Profile:  Corona , California
The rockguards should have small gaps in them, eswpecially at the bottom, for drainage.
Since your trailer is 24 years old, I would suspect bad window gaskets and perhaps even improper window latch adjustments, that could be caused by old gaskets.
We changed the original gaskets to a better style, which is "D" shaped.
It does a much better job of sealing the windows.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 07-23-2008, 11:06 AM   #4
pyanke's Avatar
Now I know there should be a gap at the bottom. I am wondering that when a PO installed the guard they may have put the center one on upside down. That would explain why the gasket gap is at the top under the hinge. Easier to mount the hinge where there is no gasket.
Pete
WBCCI #7528
1st VP MN Unit
Old 07-23-2008, 01:19 PM   #5
Commercial Vendor
The gasket at the top, is supposed to have a 2 to 3 foot gap.
Andy Rogozinski
Inland RV Center
Corona, CA
Sticky window gasket ESCAPE POD Windows & Screens 4 12-15-2006 01:18 PM
replacing window gasket silverlassie Windows & Screens 4 03-07-2004 08:41 PM
Window Gasket/Seal - Help! Herm and Debby Windows & Screens 13 07-21-2003 02:54 PM
window gasket replacement JayClay Windows & Screens 3 05-05-2003 10:35 AM
Source for window gasket jaiman Windows & Screens 2 09-07-2002 10:16 PM
