Old 10-27-2011, 01:59 PM   #1
1981 31' Excella II
New Market , Alabama
Where to get segment protectors
So where does one get these segment protectors and how much do they cost? Do you have to butcher your Airstream to install these things? They look to be made of stainless steel.
If these things cost as much as I paid for my Airstream what is the point?
Perry
Old 10-27-2011, 02:23 PM   #2
Kevin245's Avatar
If your rig isn't worth much then you might not want to pay the cost. They are made of stainless steel, and are bulky to ship so finding a local dealer may help keep your cost down.
ODMRV has them on sale right now.
Stainless Steel Wrap Protectors 1982 and Prior SKU9795 [9795] - $536.58 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Eleanor Roosevelt
Old 10-27-2011, 07:23 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
found mine on ebay, but they were still $300 plus shipping. That is still better then a hole from a rock in my lower segment!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-27-2011, 07:36 PM   #4
1974 Argosy 20
Kooskia , Idaho
I had them on one of my Airstreams, had them put on at the factory. I was disappointed that they dented up like the AL panels, and over time looked no better. They looked nice when new, however. So, my opinion is they add cost, weight, and clutter, for no real advantage. If you want to dress up an old battered front, maybe. At least they will look good for a while, but they do dent.
Like putting slip covers on a sofa, to save it for some other person? Grin.
Old 10-27-2011, 07:45 PM   #5
2011 25' FB Flying Cloud
chalk hill , Pennsylvania
rock shileds
Not so much to preserve the looks, but to protect the skin from possible holes from stones. Stainless steel will dent, but it's much harder to pierce it.
Getahobby is offline   Reply With Quote
Old 10-27-2011, 07:55 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Perry. Any Airstream dealer can order these for you. This should cut the shipping costs if you can go pick them up. Airstream.com's dealer search at the top of their page shows dealers in Montevallo, AL, Anniston, AL, Louisville TN and Alpharetta, GA.
Be sure to tell them the year of your trailer -- Airstreams became 6" wider in 1994.
I've dented up my segment protectors -- would rather have the dents there than on the actual trailer skin.
5 meter Langford Nahanni
Old 10-27-2011, 07:56 PM   #7
1981 31' Excella II
Well I think putting some mud flaps on the truck will help some. Most if not all the rocks that are going to hit that area are from the truck tires. This is why they are so low down on the corners, maybe no higher than 1ft above the belly band. Any higher than that and they would hit the bottom of the truck instead of the trailer.
Perry
Old 10-27-2011, 07:59 PM   #8
dznf0g's Avatar
Oswego , Illinois
BUT, because they are removable and stainless, the dents roll out very nicely with a body dolly. Pulled mine off this summer and worked them. From 5 feet away you can't see any dents. Up close you can see the "pocks" where metal had been displaced, but NO dents!
Also, if they get bad, they are A LOT cheaper than replacing the segments!
Old 10-27-2011, 08:04 PM   #9
Central , Mississippi
Perry,
New Market, huh? I lived in Hazel Green for a few years...still have friends there...
An alternate reason to install Segment Protectors is to cover existing damage!
Anyway...It's just a few screw holes in the front for the hinges...the side mounts are pretty important...they are riveted stand-offs and If ya only install 1 per side (Like my '91 had)...it's possible that they will rip out.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-27-2011, 08:12 PM   #10
1981 31' Excella II
I have seen some on the newer trailers that looked like they were made out of Lexan.
Perry
Old 10-27-2011, 08:13 PM   #11
dznf0g's Avatar
Oswego , Illinois
Originally Posted by HiHoAgRV View Post
Perry,
Yeah, 2 standoffs per side is necessary.
Old 10-28-2011, 05:59 AM   #12
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Perry
TOWtector works well..
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-28-2011, 06:30 AM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I pull a 25 year old trailer witout the segment guards. The trailer has taken a beating. One hole, several more near punctures, big dent that required removing and re-sealing the bottom band. If you have a fairly new trailer I would reccomend the segment protectors. I choose not to add them to an old one that already had dents. I have the full width mudflap on the truck. It does not keep stuff from hitting the trailer. The bigestst dent came from a piece of wood, like a 2x4, in the road. Saw it, but could not dodge it. Mud flaps did not stop it. End on into the trailer.
I think segment protectors cost about $800. More important, I think, are the rockguards for the curved window on front.
Old 07-02-2012, 03:16 PM   #14
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Segment "Wrap" protectors
I ordered my Segment "Wrap" protectors from Out of Doors Mart for my 1976 31' Sovereign and they arrived today. They had the best price that I could find even better than ordering from an Airstream dealer or shop.
I will post some pictures of the install and finished project.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Updates on surge protectors? Scott J-24 Batteries, Univolts, Converters & Inverters 56 08-01-2013 10:29 AM
Segment protectors tjones1881 Rock Guards, Segment & Window Protectors 7 02-05-2013 11:05 PM
Segment protectors jstokes Rock Guards, Segment & Window Protectors 0 10-07-2011 05:42 PM
segment removal and replacement purdytj Ribs, Skins & Rivets 1 07-22-2011 08:39 AM
Segment / Wrap Protector Hinge texascanuk Rock Guards, Segment & Window Protectors 2 06-10-2011 03:15 PM
