Old 07-02-2012, 05:53 PM   #15
1981 31' Excella II
New Market , Alabama
I think Outdoors Mart is an AS dealer.
Perry
Old 07-03-2012, 08:39 AM   #16
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Perry
Yes they are an Airstream Dealer. I meant more local to me here in Houston TX. Although there are no Airstream dealers here there are dealers in San Antonio and a and some service shops that I checked with and the going price was $750+ which did not include shipping.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 07-03-2012, 10:41 AM   #17
1981 31' Excella II
I have thought of making some segment protectors that mount on a frame that is attached to the a-frame in the front behind the tanks. I could probably make the frame out of aluminum and put stainless skins over it or I might be able to put Kevlar or Beta Cloth over them and paint them silver. I have some of the latter at work. We have some aluminized Beta Cloth already, just a thought. The frame would mean no attachment to the skins.
Perry
Old 07-04-2012, 12:23 PM   #18
adonh's Avatar
1976 31' Sovereign
Originally Posted by adonh View Post
I ordered my Segment "Wrap" protectors
I will post some pictures of the install and finished project.
OK I have one installed one side. Looks good. Doing it by myself took a little longer. It would have helped to have someone holding the wrap while measuring for the holes to drill for the hinge. But I got it done. As usual the instructions left a lot to be desired. The reference pictures are not that good and the instruction are a little vague in spots. But once you get going it seems to all fall in line. They included all of the parts, screws and rivets. But the small stainless steel rivets would not fit in the predrilled holes in the brackets that hold the wrap to the sides. So you have to drill these out to match the size of the rivets.
Pictures after the 2nd one is installed tomorrow.
Don Hardman
1976 31' Sovereign
Old 07-06-2012, 08:44 AM   #19
adonh's Avatar
1976 31' Sovereign
All done. They look real good and the black roll on the wrap matches the new black roll on the Airstream.
Don
ID:	162479   Click image for larger version
Don Hardman
1976 31' Sovereign
Old 10-15-2012, 07:54 AM   #20
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Perry
Two years ago I made cardboard templates for the segment protectors and took them to a sheet metal shop in Sacramento, CA. They told me that it would cost $600 for the stainless steel and the cuts. If someone can find a sheet metal shop that will make 20 - 40 of the segment protectors for less than $200 a pair I suspect that there are enough vintage owners who would be interested in buying them.
Eagle & Bear is offline   Reply With Quote
Old 01-03-2013, 09:32 PM   #21
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I do not mean to change the subject but I am tired of hunting for a thread on how to clean the stainless segments. Any advice would be appreciated. Waxing does not seem to help. Polishing?
Old 01-04-2013, 05:00 AM   #22
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
rod,
WD40 with a micofiber cloth works well for us....I do the high panels also before a long trip, the bug's come off a bit easier.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-04-2013, 07:11 AM   #23
dznf0g's Avatar
Oswego , Illinois
Stainless steel cleaner in the appliance/home section of any Wally World or HD or whatever. The same stuff you use for SS appliances. If there is some really nasty road "stuff" on them, I'll use Brakekleen first, then the SS cleaner. Wax doesn't work....gets stuck in the brushed finish and is very hard to get off.
-Rich-
Old 02-12-2018, 04:29 PM   #24
USS REQUIN 481
Pariscope's Avatar
1963 19' Globetrotter
1988 25' Excella
Reynolds , Georgia
I am waiting to see how you mounted your segment protectors. Thanks.
"rivit,rivit"
Pariscope is offline   Reply With Quote
Old 02-12-2018, 04:33 PM   #25
USS REQUIN 481
Pariscope's Avatar
1988 25' Excella
Reynolds , Georgia
What do the hinges look like and where did you buy your hardware please?
"rivit,rivit"
Updates on surge protectors? Scott J-24 Batteries, Univolts, Converters & Inverters 56 08-01-2013 10:29 AM
Segment protectors tjones1881 Rock Guards, Segment & Window Protectors 7 02-05-2013 11:05 PM
Segment protectors jstokes Rock Guards, Segment & Window Protectors 0 10-07-2011 05:42 PM
segment removal and replacement purdytj Ribs, Skins & Rivets 1 07-22-2011 08:39 AM
Segment / Wrap Protector Hinge texascanuk Rock Guards, Segment & Window Protectors 2 06-10-2011 03:15 PM
