Old 07-15-2011, 11:03 AM   #1
cojer's Avatar
1966 17' Caravel
salida , Colorado
What are these?
i have these studs above all the windows on my trailer. somebody told me they thought they were half of a type of clip used on boats? it looks as if a previous owner may have used them to attach some sort of awnings for the windows. i may try to do the same. but typing in a search for nipple thingies or boat studs took me to the dark damp recesses of the world wide web and although stimulating, shocking, and in some cases downright scary, i came up empty handed.
so does anybody have any idea what i should type into the serch bar to try and find these things?
cojer is offline   Reply With Quote
Old 07-15-2011, 11:05 AM   #2
Goal15's Avatar
Dallas , Texas
Over window grease zerts? lol
Goal15 is offline   Reply With Quote
Old 07-15-2011, 11:08 AM   #3
cojer's Avatar
1966 17' Caravel
salida , Colorado
that's kinda what they look like but they may take me to even wierder places than i've already been
Old 07-15-2011, 11:15 AM   #4
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
I've seen big grommets that have springy leaf catches in them that pop over studs that look a bit like that. The springs in the grommets grip the grooves in the studs. They kinda snap into place.
They kinda look like a big version of these, don't they?:
Lift The Dot Cloth-to-Surface
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 07-15-2011, 11:22 AM   #5
Central , Mississippi
Thats the same stud used on British convertables, I believe its called a Lift-the-dot fastener for the mate
MossMotors.com - Restoration Parts And Accessories For British Cars
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-15-2011, 11:23 AM   #6
cojer's Avatar
1966 17' Caravel
salida , Colorado
well gringo i think you got it! thank you. although a quick glance at the price of the tools used to install these things may have me running in the opposite direction. but at least now i have a starting point. thank you
Old 07-15-2011, 11:24 AM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Gringo is right. they're "Lift-the Dot" fastener male side pieces. Notice they require center hole and four slits to install the female part. If you are going to do a bunch of them, it may be wise to buy or borrow the punch tool. They were probably for covers that were weighted and hung down over the windows for storage?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-15-2011, 11:25 AM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Snap type fasteners...used by auto and marine shops. See tonneau covers.
Old 07-15-2011, 02:58 PM   #9
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Dot Fasteners. Owning vintage British sports car I know. Maybe used to hold on window covers or awnings.
DOT Fasteners, Snap Fasteners, Caps, Studs, Posts, Screw Studs, Washers and Grommets
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 07-15-2011, 06:04 PM   #10
shebeen's Avatar
1975 29' Ambassador
1995 31' Land Yacht LE
Southwest , New Hampshire
Often referred to as 'Calligula Studs'
shebeen is offline   Reply With Quote
