Old 01-24-2008, 08:30 PM   #1
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
visibility thru Window rock shield
I have a 1963 Tradewind with the original corrogated fiberglass rock shield. The aluminum frame is good, but the fiberglass is uglied out.
Of course the fiberglass shield blocks visability through the front and back windows while towing, so I am considering the solar gray / black acrylic as a replacement.
The black looks cool, but I doubt if you can see through it while towing. Any technical advice about how dark is dark enough to look good, but still allows visability? If you can see through the windows, is the awning shade effect negated?
Mike Brumback
Grand Master is offline   Reply With Quote
Old 01-24-2008, 09:20 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Welcome to the forums
My 67 Trade Wind has never, in my possession, had a rock guard. Even with the curtains open, I have never seen enough through the windows to make the view worthwhile. My guess is that this is really a non-issue, so go for the coolest solar gray you can find.
Best of luck, and keep us informed.
As always, more pictures.
Vaughan
vswingfield is online now   Reply With Quote
Old 01-24-2008, 09:30 PM   #3
Mike Brumback
We tested a "back up" monitor leaving it on for over 3 weeks, wihout a failure.
The distance between the monitor and receiver was 150 feet.
If you install a rear view monitor on the trailer license plate, and hook it into the clearance light circuit, then it will be on, whenever the clearance and tail lights are on.
During the day, you can be selective, if you wish.
At night, it would always be on, as long as the trailer lights were on.
They work very well, and cost less than $100.00 at many places, such as Costco.
This would solve your "need to see" behind the trailer when towing, with ease.
Old 01-24-2008, 09:45 PM   #4
1983 34' Excella
1967 24' Tradewind
Images: 32
Great idea, Andy!
Vaughan
Old 01-25-2008, 03:14 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Low cost back up monitors
I am interested in learning more about low cost back up monitor options where else and how much? I was at a RV retail store over the weekend and was told the systems run about a grand.
Old 01-25-2008, 05:06 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That is not entirely correct. I was at Camping World yesterday, and saw them with prices ranging from $149-499. Maybe if they hard-wired the camera and monitor into the coach wiring, and had to rip apart multiple panels, it could be that much.
This one is $119:
Wireless Back-Up Camera System with Color LCD Monitor - Camping World
Old 01-25-2008, 05:21 AM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I've started leaving curtains in the front and back of the trailer open while towing because I can see DRL's and/or headlights of following vehicles through the solar gray rock guard and windows.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-25-2008, 05:48 AM   #8
Well Preserved
1993 21' Sovereign
Originally Posted by overlander63
I just had time to hunt down the specs for that one, it has a range of 19 feet. So, unless you have a Yugo, and are towing a Bubble, that won't work so well...
Old 01-25-2008, 07:07 AM   #9
Terry.
That is the same unit that we tested that worked at 150 feet.
Old 01-25-2008, 09:00 AM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You should be able to buy medium tint acrylic or Lexan 1/8 in sheet from you local home store for less than $20 that would be about like the original equipment sold on later model trailers. If you really want to see who is following you, the trailer mirrors are sufficient for most people. In the flat country, where yoou are from, people will pass you when they get a chance. I would not worry about slowing traffic down in Indiana. They have always blown by me when I drove there.
Old 01-25-2008, 09:19 AM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
There's an advantage to the narrowness of a vintage unit. My 8'6" Safari isn't that much wider than my Argosy but it sure makes a difference for rear visibility out the side mirrors!
I towed the Argosy from out East without a rockguard in place. The large untinted front window allowed me to monitor my rear as Mike is asking. It really only worked with excellent outdoor lighting or else after headlights were on. I'd never advise using it for a sudden decision to make a turn or traffic move. A good pilot (and Airstream hauler) always flys out in front of their plane -- situational awareness counts.
5 meter Langford Nahanni
Old 01-25-2008, 09:32 AM   #12
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Glass protection / good visibility
I replaced the fiberglass protector with a 5/16, scratch resistant, dark tinted Lexan. Look at the front of any Airstream and see gravel/debris pitting. They call 'em wintow protectors for a reason. You have Corning glass? You want it protected. I wish mine was darker only because of the excessive light coming in and I am in the front seating area. As mentioned above, I have also found it a better driving feel when both front and rear curtains are opened and I can see thru to the road conditions behind. The use of rear viewing cameras, and relying on them for parking in close areas, is a good reason you see MANY Airstreams with mashed in rear panels. Use a person to marshal you in and out of tight spaces and don't ever be one who says "I think I can make it."
Name:	66 Caravel & clouds.JPG
Old 01-25-2008, 09:35 AM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I saw one at Costco last Saturday that had a color camera and night vision for $79. It transmitted its signal in the 2.4 gigahertz frequency. It could be attached to the license plate frame or mounted on the trailer itself. I was tempted....
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-25-2008, 09:53 AM   #14
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Jack
Santa (Jan) brought me the Costco $79 camera this past Christmas. The first one did not work at all and was exchanged for another. This one works, barely. The picture shakes and rolls. I have moved the antenna several times with little luck. Mine is mounted on the rear plate of my TV...
Richard
plastic shield for front window 66 overland Rock Guards, Segment & Window Protectors 4 10-06-2006 10:13 AM
2004 International CCD Rock Shield andyfuson Rock Guards, Segment & Window Protectors 9 11-17-2004 09:56 PM
Window Rock Guard balrgn Rock Guards, Segment & Window Protectors 6 10-30-2004 04:00 AM
Repair cracked rock shield? Rog0525 Rock Guards, Segment & Window Protectors 5 07-12-2003 12:53 PM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
