Old 01-29-2007, 08:28 PM   #1
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Vintage Rock Guard
I have a '61 Overlander and the rock guard on the front window is missing. There are four fasteners on the window frame. The fasteners turn 45 degrees to lock the rock guard in place. Is there a source that sells new or used vintage rock guards? Thank you for your help.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 01-29-2007, 09:22 PM   #2
airdrmr's Avatar
1967 22' Safari
Santa Barbara , California
Images: 12
Hi Rick and JJ,
I am no authority by any means, but I also have a vintage airstream that was missing the rock guard. I looked around and asked many questions - mostly I learned that even if you could find a vintage rock guard, it would most likely be too brittle us be of much use as I believe they were made of plastic. I've read that, if you're handy, you can make a rock guard by purchasing the glass and welding the frame...but we're not that handy.
We finally bit the bullet at purchase one through Inland RV. Well actually, we didn't have much choice since we lost the front window traveling down the freeway on our way to the NorCal Rally earlier this month! Fortunately Inland RV wasn't too far away and they did a great job of installing it.
It doesn't have a vintage look, but I personally don't think it detracts from the charm of our trailer. Plus, it's kind of nice to be able to see through the window while we're trailering, as Wally intended. I'm attaching a picture.
Hope this helps a little! Good luck!
Name:	leaving Inland RV with new window.JPG
Meredith
hey you, get off of my flying cloud
airdrmr is offline   Reply With Quote
Old 01-30-2007, 12:41 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Actually, our '64 has a fiberglass rock-guard, not plastic. It's a small scale, green wavy fiberglass panel framed out with about 1"x1" 90-degree aluminum. I believe the plastic ones came into existance with the Corning windows in '66.
I'll attach a picture of ours below, it's shown open but closes flat for travel. I've also seen some that had "white" (actually it's more beige) fiberglass too.
FWIW, we had ours off for a couple of weeks while polishing awhile ago and it was very nice to see through the trailer while on the road. But not nice enough to risk breaking a window while travelling. My vacation days are way too far in between to have to stop & make such an easily avoided repair while on the road.
Shari
Old 06-04-2015, 05:48 PM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Do you have a closeup of the mechanism on the sides?
robwok is offline   Reply With Quote
Texas vintage get together Pahaska The Rally Zone 33 11-21-2005 04:23 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
Lower Stone Guard Repair cesurman Rock Guards, Segment & Window Protectors 1 08-15-2002 07:22 PM
Vintage trailer rally 83Excella WBCCI Rallies & Events 0 08-13-2002 09:27 PM
