Old 03-19-2011, 02:56 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Awning
johnhh:
I have the same awning you do, in parts and pieces, that I would like to cut down and install on my '78 tradewind. Could you send me, or post, some pictures of the connection points - bottom, middle brace, and top? See attached photos.
And - what are the 'red handles'? They lock the door down when traveling.
And - can you give me a dimension from the bottom bracket to the middle bracket? 51 1/2" from the bottom of the lower bracket to the bottom of the middle bracket. There is a track attached to the skin at the top could not get an accurate measurement.
And - does the top roller end cap set into any kind of cradle? See pics
And - any words of wisdom Keep the shiny side up.
Name:	Awning Front.jpg
ID:	124893   Click image for larger version
Name:	Front Awning Arm.jpg
ID:	124895   Click image for larger version
Name:	Lower Bracket Front.jpg
Old 03-19-2011, 03:04 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Rock Guard
Lindy;
Here are the pics. There are 5 stainless steel screws holding the angle to the skin. 4 Stainless steel hinges hold the rock guard to the angle.
I would not try to attached the rock guard to the window, it may break in the process. If the drip cap doesn't stick out more than 1 1/2", the angle could go above it.
I would not recommend plexiglass; Lexan is far superior. I am considering replacing the fiberglass in the middle section with Lexan, it would let more light in.
Name:	Rock Guard Top Left.jpg
ID:	124897   Click image for larger version
Name:	Rock Guard Top Right.jpg
Old 03-19-2011, 03:17 PM   #17
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
Please excuse another thread interruption....
Mr. Twinkie,
When I look at the 'Awning Front' picture I can see the canvas bead rail extending under the awning arm. But looking just to the left side of the awning arm, under the awning roll end cap, there seems to be something else. Maybe something for the awning end cap to set on? Maybe something to catch the awning end cap stud and prevent it from unrolling in high winds?
Thanks.
John H
johnhh is offline   Reply With Quote
Old 03-19-2011, 06:06 PM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Awning
johnhh;
Here's a shot of it. Looks like it is just a pad that the awning rests on to keep it from rubbing a hole in the skin. It is just clamped to the rail.
Old 03-20-2011, 09:40 AM   #19
1967 22' Safari
1978 25' Tradewind
Mr. Twinkie,
Thanks for the shot. That bracket catches the stud on the awning end cap to arrest the un-rolling of the awning when highway driving. At least, that's what I think it is and does. How to make one is the question.
Thanks.
John H
Old 03-20-2011, 12:39 PM   #20
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Originally Posted by TG Twinkie View Post
Lindy;
Thanks Doug. That looks like something I can do but I think my drip cap sticks out more than 1 1/2". Can I just drill out the rivets and take it off then put the angle up there or would I need to put the angle up there then put the drip cap back on above it?
Also, if I do the angle and hinge at the top, do I need anything at the sides or will just the little rubber holders at the bottom hold it in place?
And, finally, what do I use to lift and hold the rock guard up when I want to open the window? Would that be something that would attach to the front of the trailer beside the windows and then to the lexan?
Nope. Now is finally - where the heck do I get Lexan? HD is 2 hours away and Lowe's is 3.
As always, I THANK YOU profusely!
lucymcdog is offline   Reply With Quote
Old 03-20-2011, 06:23 PM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Thanks Doug. That looks like something I can do but I think my drip cap sticks out more than 1 1/2". Can I just drill out the rivets and take it off then put the angle up there or would I need to put the angle up there then put the drip cap back on above it? If the drip cap is curved to match the skin it may be difficult to get a piece of angle to replace it. There is a video online showing a commercially made rock guard being installed. Just type DIY Rock Guard into your search engine. The angle will serve as the drip cap if you make sure you seal it and that the ends extend beyond the sides of the window.
Also, if I do the angle and hinge at the top, do I need anything at the sides or will just the little rubber holders at the bottom hold it in place? The angle frame will be strong enough to hold with the rubber hold downs. You might want to install holdouts at the bottom to keep the rock guard from rubbing, I did not need them because the curved pieces on each hold it out.
And, finally, what do I use to lift and hold the rock guard up when I want to open the window? Would that be something that would attach to the front of the trailer beside the windows and then to the lexan? I would make the frame wide enough to where you can install the holdup mechanism outside of the window frame. You will see one type of hold up mechanism on the video; it uses thumb screws, I'm not a big fan of those. There are the gas filled lift mechanisms like those used on pickup topper doors that open "up". They look like a small shock absorber only longer. They are pretty pricey as I recall. I don't have anything installed on mine yet.
Nope. Now is finally - where the heck do I get Lexan? HD is 2 hours away and Lowe's is 3. There is an online place called "eplastics.com" that you can buy it cut to the size you need. Don't know what it will cost. If you tell them what you want to use it for, perhaps they can recommend how thick it should be. I would guess no less than 1/4".
Old 03-22-2011, 07:21 AM   #22
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Lindy;
More questions:
Is the angle stuff aluminum or stainless?
Do I get "C" channel to go around the Lexan or is that angle?
Do I need to worry about the frame of the rock guard rubbing against the trailer? If so, what do I need to put on the frame to keep it from rubbing?
Are those just little hinges or is it like a piano hinge?
What are the hold out arms called so that I can look for some?
Is Lexan the polycarbonate stuff?
Thanks!
Old 03-22-2011, 08:02 AM   #23
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
More questions:
Is the angle stuff aluminum or stainless? Everything is aluminum. The screws to fasten the 1 1/2" angle are stainless steel #10 x 1".
Do I get "C" channel to go around the Lexan or is that angle? I used angle and flat stock in order to be able to clamp the fiberglass (Lexan in your case) tightly between the two pieces, the angle and the flat stock. I put the drawing here again. Note how it is like a sandwich, the rivets go thru the angle, the fiberglass and the flat stock, clamping it together.
Do I need to worry about the frame of the rock guard rubbing against the trailer? It depends on how close the rubber hold downs will hold it and the pressure from the wind as you drive down the road.
If so, what do I need to put on the frame to keep it from rubbing? I would think you could use something like a rubber pad thick enough to keep the frame from rubbing on skin or frame of the window. I would fasten the pad to the skin or window frame not to the frame of the rock guard; there will be some scrubbing action fro the wind and you want that to scrub on the frame not the skin. There are a number of different styles of rubber pads with holes in them for mounting. I'll see what I can find when I get some time to look.
Are those just little hinges or is it like a piano hinge? I used 4 each 2" stainless steel hinges (refer to the pics I posted) if you click on the picture it should enlarge to where you can see the hinges., I couldn't find anything but steel or brass piano hinge. The steel will rust and the color of the brass just didn't look good to me.
What are the hold out arms called so that I can look for some? I'll have to do some searching for a definition of the part.
Is Lexan the polycarbonate stuff? If you go to the eplastics.com website they list Lexan and I think it is polycarbonate and I'm not sure what Plexiglass is made of. But the Lexan type material is what I would recommend.
window protectors, rockguard
3 piece rock guard for a 31' Sovereign? ryan3326 Rock Guards, Segment & Window Protectors 4 09-02-2009 08:21 PM
Rock Guard Dieselgrin 1970 - 1973 Sovereign 2 11-14-2008 01:16 PM
Will the 3-piece rock guard from an 83 Excella Fit My 76 Arogsy? AndyPenny Rock Guards, Segment & Window Protectors 12 05-16-2008 08:57 PM
is a rock guard necessary? flyingcloud Rock Guards, Segment & Window Protectors 33 07-28-2005 03:28 AM
