Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 06-21-2002, 02:06 PM   #1
74Tradewind
74Tradewind's Avatar
Profile:
Stone Guard/ Keep it or Remove it?
Is this stone guard a desirable item? Looks kinda ugly. I guess I could polish it up. The body behind it is perfect. Was this an option? I would rather have a window cover. It would really look goofy if I had both guards don't you think?
74Tradewind is offline   Reply With Quote
Old 06-21-2002, 07:19 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
It depends on where you plan to tow. Lots of back country, gravel roads I wold keep it. I did not have a lower rock guard on my 77 Sovereign but you could see the wear from rocks etc. I had the rock guard over the front window. I think it is a better option as the windows are big $$$$.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 06-21-2002, 09:10 PM   #3
83Excella
83Excella's Avatar
Profile:
The rock guard looks fine to me, it's there to keep the skin from getting dinged up not to be stylish. I would put on on the front window too you'll wish you had if the window eats a rock.
John
83Excella is offline   Reply With Quote
Old 06-21-2002, 11:32 PM   #4
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Polish it up. They look pretty cool all nice and shiny. This is also going to stop that 65 mph rock from denting the shell.
Regards;
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 06-22-2002, 08:22 AM   #5
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Keep it!
Flying gravel is a fact of life here in Texas. The gravel guard is a must-have option for me.
I would polish it up and keep it.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 06-22-2002, 10:55 AM   #6
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
If you want small dents throughout the front of your trailer then by all means remove it. I have a rock guard over my front window but none over the front lower panels. I have had 4 new dents in the front panels that have made me sick. They will stick out like a sore thumb when I polish my trailer. I'm sure you will feel the same way once you drive through gravel and later hit the blacktop. A rock thrown from a tire at 60-65 wrecks havock with soft aluminum skin. Just my 2 cents worth. Craig
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-23-2002, 03:00 PM   #7
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Personally I would keep the stone guard.
Considering if mine ever got too ugly or took a big hit, I could replace them. I think the cost of replacing the stone guard is a lot less than removing and replacing a front panel.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 06-24-2002, 08:40 PM   #8
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Another reason
I do not have a guard like your pic. And I lost a tire (right rear) on my van the last time I towed. The tread flew off. It was an older tire with tread and a warrantee. And it did not cover damage to my van or the beauty mark on my bullet. Just got a new tire
>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 06-26-2002, 12:07 PM   #9
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
what do you suppose a lower stone-guard would cost? I'd assume that model #/size of the trailer shouldn't matter much...they all look the same from the front! just curious...perhaps I'll add one, if they don't cost an arm and a leg.... Oh, and how do they attach?
Old 06-26-2002, 02:09 PM   #10
davidz71
davidz71's Avatar
Check www.inlandrv.com. I believe they have them in stock. I priced them at one time but have forgotten what they run.
Craig
AIR #0078
3.73 rear end
How to modify and install rock guard on minuet Janet All Argosy Trailers 42 09-29-2008 07:54 PM
Window Stone Guard What to do? GT1963 Rock Guards, Segment & Window Protectors 30 08-31-2006 10:49 PM
Looking for a stone guard -1976 Argosy James Martin Rock Guards, Segment & Window Protectors 5 11-28-2005 08:49 PM
How do I remove the electric reel? k5cad Airstream Motorhome Forums 6 11-26-2003 07:16 PM
Lower Stone Guard Repair cesurman Rock Guards, Segment & Window Protectors 1 08-15-2002 08:22 PM
test
