Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 01-24-2008, 12:19 AM   #29
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
Curvature issues....?
Dwightdi -
Saw your post and thought I'd add this question to the mix.
Are any of the types of "poly" you described more, or less, amenable to bending? Reason I ask, I have a front rock guard that need replacing, but it is a wing section ie it has a bend to it. Would REALLY like to see to this repair/replace myself..... but.....
Is there one or another, poly/ lexan/ other, that is better, preferable, or simply 'best' when it comes to replacement of these wing/bent units?
Just wonderin'
Thanks!
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 01-24-2008, 08:48 AM   #30
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
There are two kinds of acrylic. The one they used was a thermal plastic and could be heat formed at about 250-290 F. It does not need to be dried before you heat it. It can be bent with a heat shrink gun or a paint peeler type hot air gun or radiant heat source. Polycarbonate should be dried before you try and heat it too high. It absorbs water in normal conditions and will bubble up if you try to heat it too fast. If you get it dry, you can bend it successfully when it reaches about 350 F. You can evaluate the amount of stress in either PC or acrylic by using a polarized light source on one side and an other Polaroid filter to look through from the other side. Rainbows indicate the severity of the stress. Slump heating, in which the material losses enough strength to simple relax and fall to contact a wood mold give the least stress. A little gentle encouragment usually is not too bad. A cold bend with result in high stress in PC and will crack acrylic. By the way, some sheets Acrylic also comes as thermal set grade material and will not lose strength when heated and so can not be formed.
Old 02-29-2008, 11:01 PM   #31
campernut64
Alumaholic
Profile:  Currently Looking...
Cambridge , Ohio
Question Window Question
Dwightdi,
I've got a '49 Spartan Mansion I'll need to do curved window replacement on. It still has the original (I assume) acrylic in place but is badly star marked and crazed. Most of the Spartanizers seem intent on Polycarb but unless they use enough thickness (requiring heat bending) the windows tend to blow/pop out on them. I would probably use Polycarb too if I could but in my research I too found that drying is required to stress relieve/ bubble prevention. I'm familiar with resin drying (I work with PET injection molding and stretch blowmolding at the bottling plant where I work), but wonder if you could give me some info on Sheet material drying. Is this something that could be "homebrewed"? I work in maintenance and have the tech skills to build apparatus or a heating oven but I don't know anything about reqd. temp/ dewpoint, time to dry etc. Is this feasible and or worthwhile, or should I stick with Acrylic/ Plexi that doesn't require drying to heat bend? ...I guess 59 years is pretty good for the original windows. Also, what should I look for in fade/ UV protection. Any books on the subject you know of?
Thanks, Brad
campernut64 is offline   Reply With Quote
Old 02-29-2008, 11:22 PM   #32
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 18
Try this
When I was restoring my old Fighters I had a canopy maker in LA make several plexiglass/acrylic canopys for me. He made a plaster form and heated the material over the form in a large oven affair. There are several places where you can still have that done and I am sure your windows would not be a problem.
Old 03-01-2008, 12:12 AM   #33
campernut64
Alumaholic
Cambridge , Ohio
I've never heat formed anything this large before but interestingly enuf I too was thinking of a plaster form cast from the inside surface of the original. Did your source use any coating/covering over the plaster or just on the bare surface? I seem to remember reading once of laying felt or flannel over the forming surface to protect the plastic from damage.
I have access to heating elements from several machines where I work so the oven shouldn't be too much trouble. I also have a buddy who has done Plexy/ acrylic forming as a resource but he does'nt have any background in Lexan/Polycarb drying if I were to go that route.
The more I mull this over the more I'm thinking Plexy may be the cheapest, easiest route to take.
Thanks for your info,
Old 03-01-2008, 08:43 AM   #34
Melody Ranch
1947 22' Liner
Valley View , Texas
Images: 18
mold covering
Yes, the plaster mold form was covered with a felt or cotton cloth.
Old 03-01-2008, 09:02 AM   #35
dwightdi
McHenry , Illinois
GE owned and produced Lexan until recently. They had some very good Tech literature which might be available off the web. Sarbic recently bought the name, business, and people from GE. I have not done business with them yet. Drying proceedures and vac forming used to be in their literature. You need to be about 220 F to get effective drying. You need to be about 100 F higher temps to do the vac forming. From memory, I think it was about 350F. Acrylic would be easier to do and half the money but can be fairly easily broken by flying rocks. Spartans were never intended to be really road machines like the Airstreams and so did not need to be as resistant to abuse.
Old 03-01-2008, 11:23 AM   #36
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
As the story goes the USAF exported their canopy chicken cannon to Canada or Britain so they could check their latest NATO design and completely destroyed several of their best designs - As you can imagine it took some long-distance trouble shooting over velocities and mounting etc. and it was by deduction from a description of how messy a raw chicken can be that it dawned on the other end of the line "Oh gawd - you mean we should thaw the bloody birds!...
Mar-guard scratch resistant lexan is great stuff and comes in some 20% tints, but the lexans and polycarbonates etc. with scratch resistant coatings will not heat form without stripling the coatings into zebra stripes.
Rain-X does a great job reducing hazing - crazing - sand blasting - UV damage on polycarbonate. Be generous so it can fill the pores and dry slowly in the pits and scratches, use a couple of coats.
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 03-01-2008, 11:27 PM   #37
campernut64
Alumaholic
Cambridge , Ohio
As to drying Lexan/ polycarb....... Is the drying done with dehumidified (over a desicant bed)air or just by heated air only. The dryers we use for resin drying are hoppers which have dehumidified and heated air blowing thru them. I didn't know whether the desicant was required for lexan or not. Anyone know???
Rock Guards Gunnyusmc Rock Guards, Segment & Window Protectors 4 08-23-2007 08:59 PM
SF Bay Area - Need Help w/ Lexan (polycarbonate) source Mookie Windows & Screens 3 03-19-2007 10:56 AM
Rock Guards for Aistream a-wanabbee Rock Guards, Segment & Window Protectors 3 03-16-2006 08:29 PM
Where to get rock guards? Nicksut Rock Guards, Segment & Window Protectors 3 09-23-2004 12:27 PM
Walbernized the rock guards and... Kistler Our Community 12 03-10-2003 08:12 AM
test
