Segment / Wrap Protector Hinge
My '91 Excella wrap protectors have a regular piano hinge where they attatch to the rivet line on the front of the trailer. the trailing edge is secured by 2 rubber receptacle /base mounted to body and locking screw on protector. After a 5600 mi trip these rubber receptacle and screw arrangement have given me so much trouble that I finally had to take them off and throw them inside the trailer. I'm going to replace the mounts with a more modern "3 point hold back system" as seen on current units.
Q. I noticed that the hinge on the new units is not a flat piano hinge, but an L shaped hinge that would get the protector out from the body more than a flat piano hinge. Where do I get new hinges?
The hold back mounts have holes that fit a 1/8" diameter rivet. IMO these could be too weak to serve the purpose and I may go bigger. Anyone have problems with the strength of the 1/8" rivets?
Thanks in advance.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
