Old 11-15-2007, 08:48 PM   #1
1971 23' Safari
MUSCLE SHOALS , Alabama
Question Segment Protector install
To install segment protectors, where in relation to the vertical row of rivets on the front panel of the AS does the piano hinge attach?
e quigley
equigley is offline   Reply With Quote
Old 11-16-2007, 05:59 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
vertical ribs
There are two vertical ribs, one on each side of LP bottles, below front window. They are pretty obvious because there are many rivets in a vertical pattern. If all else fails, look at another unit with the protectors installed.
Smily
smily is offline   Reply With Quote
Old 11-16-2007, 06:11 AM   #3
Still Working
smily's Avatar
1994 36' Classic 36
An example
http://www.airforums.com/forums/f44/...ig-1950-2.html
Old 11-16-2007, 07:57 PM   #4
1971 23' Safari
This row of rivets in the two vertical ribs is the reason for asking the above question.
Do these rivets have to be removed to attach the segment protector piano hinge? Or, is the vertical strut wide enough to position the piano hinge on one side or the other of this row of rivets in order to drill the new holes for mounting the segment protectors?
e quigley
Old 12-02-2007, 10:41 AM   #5
1985 25' Sovereign
Valley Center , California
e quigley
I just ordered a set of segment protectors for our '84 Sovereign from Inland Andy last week. I'll have the same installation questions, I imagine, that you will since our trailer did not have them previously installed. (We are concealing a basketball sized dent with our segment protectors. )
Maybe we could share some pictures, etc. I have done a lot of searches on this forum but cannot find the exact info for mounting these.
Chris
BogieGolf is offline   Reply With Quote
Old 12-02-2007, 10:55 AM   #6
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Gaurds
Hello, Here they are on my 71 Safari.
Name:	segment gaurds 001.JPG
ID:	50248   Click image for larger version
Name:	segment gaurds 002.JPG
bertro is offline   Reply With Quote
Old 12-02-2007, 12:55 PM   #7
bertro's Avatar
1971 23' Safari
Groveport , Ohio
I forgot
Here is a pic of the hinge fastened to the rib over the rivets. Mine came on the trailer and I dont know if the install is correct but they fit well. Robert
Name:	segment gaurds 1 001.JPG
Old 12-07-2007, 05:03 PM   #8
1971 23' Safari
Thanks all for the replies and photos.
I recently looked at a new AS and it does appear that the hinge is mounted on top of existing rivets. It just doesen't seem like the best idea.
I know this is getting close to being over analyzed and I'm going to mount the things and be done with it, but I would like to know how wide the vertical struts are and if there is enough room on one side to drill and mount the hinge.
Need a source for Segment Protector latch R&SZinser Rock Guards, Segment & Window Protectors 10 02-28-2019 11:57 AM
Segment Protector install equigley 1969 - 1973 Safari 3 02-07-2015 07:05 AM
Segment protector ticki2 Rock Guards, Segment & Window Protectors 4 10-21-2008 05:53 PM
Protector of the frame ArtStream Repairing/Replacing Floor &/or Frame 0 08-14-2006 01:32 PM
?? Lower segment protector fit ?? driftwood Rock Guards, Segment & Window Protectors 1 03-07-2005 04:09 PM
