Old 09-25-2004, 09:23 PM   #1
jhart657's Avatar
2007 25' Classic
1993 21' Sovereign
Elm Grove , Wisconsin
Thumbs up Rockguard Repair on '93 Sovereign.
My '93 Sovereign 21 footer had a cracked Rockguard (the plexiglass cover over the front window) I looked into replacing it and found out that it would cost $350 plus shipping. Sounded like a lot of money! I checked various forums as to the possibility of just replacing the plastic instead. Had anybody done this? Nothing found!
I looked into replacing the plexiglass with Lexan.(Less chance of cracking and also color choices) I found a local shop that ordered smoked Lexan for me and then cut it to size. The only thing that I needed to do beyond that, was to cut the rounded corners with a skill saw. I used the old cracked plexiglass as a template. Perfect results! I drilled out the rivets and replaced them with S/S sheet metal screws. The frame had to be cut at the top in order to slide in the new Lexan. (The cut was done on top because the hinge contributes to the strength of the entire frame) The Lexan is held tightly in place by a rope-like beading.
The Rockguard is better than new. Total cost $80.00!
jhart657 is offline   Reply With Quote
Old 09-25-2004, 10:01 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Thumbs up WTG jhart!
And welcome to the forums. The lexan or plexiglass can be replaced in the newer rockguards but I don't know of anyone who's had success in replacing the older bubble contoured plastic in the weaker frames.
Refer: http://www.airforums.com/forum...ight=rockguard
If anyone has had success, I'd like to hear about it since I have a '71 rockguard frame gathering dust in my workshed.
Rog
May you camp where wind wonít hit you, where snakes wonít bite and bears wonít git you.
Rog0525 is offline   Reply With Quote
Old 09-30-2004, 09:37 PM   #3
aztlanco's Avatar
El Paso , Texas
Send a message via AIM to aztlanco
Lexan is the way to go! I replaced all my glass windows with Lexan and fount it easy to work with. You can cut it with a jig-saw and it wont shatter like plexiglass. It is also significantly lighter than glass and you can buy it at any glass or plastics supplier.
Ernie
'58 Traveler 18ft.
aztlanco is offline   Reply With Quote
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Bellypan Rivet Repair 66Overlander Belly Pans & Banana Wraps 19 09-15-2004 02:58 PM
Rear Bath Floor Repair trogers713 Repairing/Replacing Floor &/or Frame 7 10-26-2003 06:43 AM
Rear Bath Floor Repair trogers713 Repairing/Replacing Floor &/or Frame 1 10-24-2003 08:30 PM
Repair 84 Sovereign Front Interior Panel Cecil Stone General Interior Topics 4 08-27-2003 05:31 PM
