Old 08-18-2007, 08:20 AM   #1
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Rock Guards
While washing my trailer I discovered cracks in my rock guards.
My dealer advised me that the newer rock guards are cracking and are covered under warrenty. The cracks are not visible from the outside, but can be seen from the inside. The cracks will be vertical on the curve.
It would be a good idea too check your rock guards.
Don
Gunnyusmc is offline   Reply With Quote
Old 08-18-2007, 08:29 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Good info to know. Is this just for the 06 model year or do they know if other model years are effected.
This would be some great info to put on the QC threads.......
Old 08-18-2007, 09:07 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Thanx for the heads up. I'll check ours later today.
SuEllyn & Brian McCabe
Old 08-23-2007, 07:59 PM   #4
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Got 'em
I was noticing the "striations" in my rock guards. Can't see them from the outside, but from the inside they are quite noticable. I will contact AS tomorrow. Thanks for the heads up.
altamont is offline   Reply With Quote
Old 06-28-2009, 08:16 PM   #5
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Both rock guards affected
My husband was just washing our A/S too and noticed huge cracks on the road side rock guard. We were sure a bird hadn't hit and they are vertical cracks. I came in to search the forum and saw this thread. After reading, we went inside to look out and sure enough the curbside rock guard was also crackly, but not visible from the outside. Here are our pics of the road side - from the outside and inside- and the crackly rock guard on the curbside.
Is this really covered under warranty?
ID:	83089   Click image for larger version
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 06-28-2009, 08:25 PM   #6
Those cracks are not caused by being hit with something.
They can be caused by the original cover paper being on the plastic for a long period of time, suggesting "old" plastic.
Cracks like that have nothing to do with a slight bend that's in most rockguards.
Since it's a defect, it most certainly should be covered by warranty.
If your refused warranty coverage by a dealer, then I would suggest you contact the factory, immediately. You can arrange for a replacement later, but it's important to inform the factory asap.
Old 06-28-2009, 08:59 PM   #7
bolerama's Avatar
Images: 30
Thanks so much, Andy. We will get on it first thing Monday morning.
Lisa and Paul
Old 06-28-2009, 09:08 PM   #8
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We have a "crack" that looks more like a star crack in a windshield in our center rock guard. Can't see it from the outside and I've managed to ignore it for a year now.
Gene
Old 06-28-2009, 09:32 PM   #9
bolerama's Avatar
Images: 30
Gene
We have one of those on our center rock guard, and we're pretty certain that it is indeed a rock chip because of the "star" pattern. We got it on one of our first trips. These vertical cracks on the side rock guards look very different. They look kind of like tempered glass that has been broken, but only at the curved areas. It made my stomach flip-flop when I first saw them. The cracks are huge. I was pretty shocked to see them.
Lisa
Lisa and Paul
Old 08-27-2009, 09:32 PM   #10
bolerama's Avatar
Images: 30
New Rockguards!
Airstream sent us new rockguards. We have to send the old ones back so that they can investigate them. We are so pleased. The new ones didn't line up with the original catch on the body of the Airstream by 1/4 inch. Paul had to lower the catch on the rockguard...better to drill new holes on them than on the body of the trailer. Airstream had not heard of this issue before we contacted them. I hope this is a rare occurrence.
Lisa
ID:	86207   Click image for larger version
Lisa and Paul
Old 08-27-2009, 10:08 PM   #11
StingrayL82's Avatar
San Angelo , Texas
Images: 37
A good preventive measure, you might want to keep in the back of your head, is to make sure that, if your rockguard is exposed to sunlight, it will be hot and, if you were to wash your rig with cold water, the rockguard will crack.
As an experiment, get yourself a set of clear, thick plastic water glasses and throw one in the microwave for two minutes, then take it out and try to fill it with cold water...I sorta kinda did this by accident, except I pulled the plastic glass out of the dishwasher, which had just finished drying....you will get the same vertical striation cracks you had in your rockguard, guaranteed.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 08-28-2009, 04:48 AM   #12
SilverCottage's Avatar
LONDON , ON
This makes me upset. I noticed 2-3 cracks on our rock guards last year while it was under warranty but didn't mention it because I thought we had hit something. Now I find it is a manufacturing defect.
We are 5 months out of warranty. Does anyone think I can get these replaced as a goodwill gesture?
SilverCottage is offline   Reply With Quote
Old 08-28-2009, 08:08 AM   #13
Master of Universe
Gene's Avatar
Call Airstream customer service and ask. You have nothing to lose by trying.
I have what looks like damage from an impact, but if the rock guards are defective, it could be more prone to such damage. I'll ask when we go to JC just before the warranty runs out about whether they are covering that.
Gene
Old 09-01-2009, 05:11 PM   #14
1977 Argosy 20
Sunnyvale , California
We are looking to buy a rock guard but now I'm a bit nervous too. Is this happening to the new ones? Any suggestions on where to buy from?
Argosykelly is offline   Reply With Quote
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 09:50 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
rock guards segment protectors joecj76 Rock Guards, Segment & Window Protectors 21 07-02-2003 10:54 AM
Walbernized the rock guards and... Kistler Our Community 12 03-10-2003 07:12 AM
