Old 03-17-2012, 09:23 PM   #1
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Rock guard mishap
Our curbside rockguard (that piece if a three-piece rock guard) was broken yesterday. is it possible to buy just one piece? Does anyone put there have one to sell? Is it possible to glue one back together? It is sn 89 excella.
Skatiero is offline   Reply With Quote
Old 03-17-2012, 09:43 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Yes, they sell just the one piece.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 03-18-2012, 06:35 AM   #3
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Thanks, Clancy Boy. Do you know where I should look? I am kind if hoping we can repair ours but only if we can either glue the plexiglas or get just the plexiglas ...
Old 03-18-2012, 06:59 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
pictures
Skatiero
I would get some pictures of it and call one of the parts guys at Out-of-Doors Mart. They have been known to carry some used ones that they can let you have for cheap and if no used ones they know which one goes on what year. Airstream has a few of them and you will want to make sure you get the right one. I know measuring from top to bottom is one measurement you going to need before ordering.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 03-18-2012, 07:03 AM   #5
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I know Out of Doors Mart, and Inland RV both carry separate sections. I take it in its breaking, it was sacrificed to save your window? FWIW, a new curved window costs more than an entire set of the guards.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-18-2012, 08:20 PM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Thanks, guys! The mishap actually happened in our driveway! Rob had and is doing everything one-handed and it got away from him. We actually got it pieced back together, two corners are cracked all the way through. What glue can we use to finish the repair? We would lov to fix rather than replace!
Old 03-18-2012, 08:36 PM   #7
That plastic can be fused back together using a "plastic solvent".
I have no idea where you might find a small quantity.
Old 03-18-2012, 09:25 PM   #8
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Thanks, Andy! Anyone know where I should look for that plastic solvent? any brand names?
Old 03-19-2012, 06:05 AM   #9
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Katie, You might try either a glass shop near you or a higher end auto body shop as a starting point.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 03-19-2012, 06:16 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Plastic welding...
Welding solvents..
Hope this helps...
HITC....🌥
Old 03-19-2012, 06:34 AM   #11
1988 25' Excella
Trumbull , Connecticut
fusing plexaglass
Hello all. When I worked in the electronics lab we built many test boxes out of plexaglass andwe just used accetone to weld them together and it worked great. Hope this helps.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 03-19-2012, 11:39 AM   #12
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
You all are the best! I really, really appreciate the help and advice!!
Rivets for window rock guard hinge arcamedies Rock Guards, Segment & Window Protectors 5 12-30-2012 06:20 AM
Giant rock towed to Lakewood ROBERTSUNRUS Off Topic Forum 61 06-25-2012 08:58 PM
1957 Calif. Airstream Overlander. 1/434 Elvis, Rock & Roll & The National Parks eBay Watch Airstreams on eBay 0 03-15-2012 10:10 PM
Southwest Arizona: Kartchner Caverns, AZ & Rock Hound State Park, NM Ray Eklund Boondocking 6 02-25-2012 02:26 PM
Reattaching a Rock Guard Bettye Rock Guards, Segment & Window Protectors 5 02-17-2012 07:34 PM
