Old 07-08-2013, 10:41 AM   #1
1994 28' Excella
St. James , Missouri
Rock Guard Glass Replacement
Hi-
I have a 1994 Excella 1000. The 3 piece rock guards was heavly damged in a recent hail storm. The plexi on all 3 panels needs to be replaced.
I can purchase a new for a replacement 3 piece set for $1,000 but I would rather not spend this much.
The aluminum frames are undamaged and can be reused if I can find replacement plexi.
Anyone know if you can purchase the plexi only?
Thanks in advance!
Mark
Mark910234 is offline   Reply With Quote
Old 07-08-2013, 10:54 AM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I did this just recently on my Safari Rock Guard.
I purchased a 4x8' sheet of 1/8 PoliCarbonate from a local plastic manufacturer I found on the internet for about $150. My rock guard frame disassembled by drilling out 4 rivets and removing the hinge. I then used what was left of the original Plexiglass as a template and cut the PoliCarbonate with a fine tooth blade in a jigsaw. I took some trimming to get it to fit exactly how I wanted. The rubber gasket had become very hard and broke in to many pieces during disassembly. I used a tube of rubberized sealant around the new PoliCarbonate and reassembled the frame.
The results were great, and the PoliCarbonate should be much tougher than the PlexiGlass. PoliCarbonate may not be as resistant to abrasion as the Plexi, but for the cost and effort I won't mind if I have to replace it again in a few years. I bought a slightly lighter tint than the original since it was in stock. The lighter tint allows me to see better out the back window of the trailer when towing.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 07-08-2013, 12:16 PM   #3
1994 28' Excella
Thanks!
Did you replace the curved side guards also?
Old 07-08-2013, 04:19 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Links? To source?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-08-2013, 04:56 PM   #5
aquinob's Avatar
Portsmouth , Virginia
Just did this repair as well. Purchased the acrylic in a darker charcoal tint for about 80 bucks cut a bit oversize from a local plastics distributor. Disassembly was mostly drilling out the rivets. In my case I painted the aluminum frame black, though I'm not sure I would repeat that. On my unit, the plastic was 1/8th thick and I was able to reuse the rubber pieces that hold it in the frame.
Original:
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 07-09-2013, 07:00 AM   #6
1994 28' Excella
That looks awesome! About how much for materials?
I know it's less than purchasing a replacement.
Mark
Old 07-09-2013, 07:05 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Don't use Plexiglass. It's hard to cut and subject to UV degradation. Use Lexan (polycarbonate). Make sure to get the UV resistant type. There should be a plastic supply source in any city
Old 07-09-2013, 09:31 AM   #8
aquinob's Avatar
Mark
Initially I spent 80 bucks on the replacement acrylic which would have been enough to do everything, but I ended up cracking one of the side panels (note to self, never try and rivet into the plastic) and had to pony up another 20 for an extra piece. If you want to add the cost of the paint, probably another 12 bucks or so.
Old 07-09-2013, 10:32 AM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
I had to buy a whole sheet of Lexan. I don't remember how much, but not that much. I bought it at a plastic supplier in Albuquerque. UV resistant was not in stock, neither was tinted. If I wanted either it would be a special order which would at least double the price. As it were, the non UV resistant Lexan has yellowed quite a bit over the past 5 years but does not appear to have lost any strength.
And you can drill through Lexan for rivet holes. Plexi will crack.
Old 11-21-2013, 06:38 PM   #10
KYAirstream's Avatar
Northeastern , Kentucky
Looks great. How did you achieve the curve in the lexan?
KYAirstream is offline   Reply With Quote
Old 11-21-2013, 09:19 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
When trying to find in Austin area, the suppliers talk to me like they are HAMs and I an a mere interrupt in their reality.
Think "Sheldon" off "Big Bang Theory" TV show.
Anyone know "friendly" supplier in Austin or Texas?
Peace
Channing
Channing
WBCCI# 30676
Old 11-22-2013, 03:29 PM   #12
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Used to 'mold' curved Plastic - as I remember the temperature melding point was 345 degrees so we would put the plastic in a curved frame and heat to 340 or so - if it will fit in a kitchen oven with window - you can watch and stop the heat (open door) when it sags and fits the mold. Was easy to do - the slight bend of these rock guards probably could be done with a heat gun into a form of some sort.
Silver Hawk is offline   Reply With Quote
Old 11-22-2013, 03:35 PM   #13
When heating, do you have any trouble with getting bubbles inside the lexan?
Old 11-22-2013, 03:59 PM   #14
1975 31' Sovereign
"When heating, do you have any trouble with getting bubbles inside the lexan?"
No - you don't get it that hot. Bubbles come when you get it so hot that it's about to burst in to flame - past melt time, not sure what temp. that would be but probably around 400 degrees - it's petrolatum base. Only time I got bubbles was when I used a propane torch to get rid of the sandpaper scratches on edges of plex and Lexan and held it on to long (torch).
Reattaching a Rock Guard Bettye Rock Guards, Segment & Window Protectors 5 02-17-2012 07:34 PM
Rock Guard replacement parts arcamedies Windows & Screens 2 12-02-2011 05:38 AM
Poor Man's Rock Guard perryg114 Rock Guards, Segment & Window Protectors 9 10-05-2011 10:15 AM
Rock Guard Flips Off (2005 Classic) DL46 Rock Guards, Segment & Window Protectors 6 05-05-2011 11:58 AM
Hehr window glass replacement for '58. mello mike Windows & Screens 4 02-25-2011 08:36 AM
