Old 10-20-2011, 12:57 PM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Rock guard frame measurement-66 Safari
I am looking for the outside measurements for the front rock guard frame on a 66 Safari. I do not have a frame but would like to attempt to duplicate the original size to take advantage of the already existing holes from where the old one was. Thanks guys/gals...
Bary & Karen in Mich.
goshawks00 is offline   Reply With Quote
Old 10-20-2011, 01:18 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Not sure whether 64 and 66 would be the same.
On my 64 it is 46.5" x 24" and made from 1 " alum. angle
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-20-2011, 01:19 PM   #3
The latest version is 47" x 26".
Old 10-20-2011, 02:30 PM   #4
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Thanks Rick, that sounds a bit wide I think... If you can take another measurement for me I would really appreciate it. On the 66 safari there is still attached to the body the upperstone guard support arm brackets.. I am talking about thebracket that you loosen the screws on both side so you can pull the rock guard up.
So, the rock guard support arms attached to the body are 41 1/2" between the two brackets. Can you possibly get that measurement for me...
BTW the hinge that swings the guard out is 44", so maybe the arms are inside of the frame instead of the outside....hmmm...
Old 10-20-2011, 02:44 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
It may we;; be the 64 front window was different however the proportion might help
The hinge on top is 42". It is shorter than th guard or window frame.
The brackets the support arms are on are 45.5" center to center.
The window itself including frame is 44.5"
Sounds like your window may be a bit narrower. The arms do attach inside the frame
13 Ram 2500 TD
Old 10-20-2011, 03:49 PM   #6
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Thanks Rick hopefully someone with a Safari can furnish their measurements. I suppose I could just make a guard and install things where ever they end up but I would like to keep the original proportions if possible ( and avoid more hole to fill!)
Barry & Karen in Mi..
3-Piece Rock Guard installation tips? Gkiesel Rock Guards, Segment & Window Protectors 6 07-01-2013 07:34 PM
Poor Man's Rock Guard perryg114 Rock Guards, Segment & Window Protectors 9 10-05-2011 10:15 AM
Had a nice window rock guard made reasonable Hummer Rock Guards, Segment & Window Protectors 12 08-24-2011 12:09 PM
Where 2 buy 83 Sov window rock guard nustreamer Rock Guards, Segment & Window Protectors 2 07-16-2011 01:21 AM
Rock Guard Flips Off (2005 Classic) DL46 Rock Guards, Segment & Window Protectors 6 05-05-2011 11:58 AM
