Old 03-17-2012, 10:39 AM   #1
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Rivet Rivets for window rock guard hinge
I have a 93 excella and one of the rivets was loose on the hinge for the right stone guard so I popped it out but soon realized it's a shallow well pocket and my rivet gun will not go between the glass frame and the stone guard to resecure it. What type of rivet is used for this hinge attaching to the stone guard?
(I've seen plastic ones that you pop the head in and the base expands but not aluminum ones)
arcamedies is offline   Reply With Quote
Old 03-17-2012, 11:32 AM   #2
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Hi arcamedies:
I just had to replace the plexiglass in my rock guard frame due to warpage and a rock strike. Removing the rivets caused me to change the hole diameter for the rivets in a few cases. I found it much easier to through bolt with SST machine screws and nilock nuts. It'll make the next replacement easier by a long shot and it does'ent look bad at all.
Hope this helps.
Del Gurney is offline   Reply With Quote
Old 03-17-2012, 12:33 PM   #3
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
What Del Gurney said. It Worked for me. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-18-2012, 09:02 AM   #4
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Keeping it original
Originally Posted by Del Gurney View Post
Hi arcamedies:
Hope this helps.
Thought about that but trying to keep it original so look for what goes there from the factory if possible.
Old 12-30-2012, 05:40 AM   #5
Centennial , Colorado
Hi arcamedies:
Hope this helps.
Can you tell me where you got the new plexiglas? I have a side rock guard that I need to replace the plexiglas on. I think I need a new piece cut and riveted but I don't know a supplier of plexiglass to contact. Any contact you could give me would be greatly appreciated. Thank you.
drevell7 is offline   Reply With Quote
Old 12-30-2012, 06:20 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can find suppliers on the net. But plexiglass is not the right product. You want what is known as "Lexan". It is more suited for use as a rock guard.
Awning for '60 Safari prhamilt Windows & Screens 15 05-15-2012 08:48 PM
Looking for 1967 or 1968 Safari if Anyone Sees One, Thank you! Mary Burris 1966 - 1968 Safari 5 04-27-2012 04:38 PM
Getting Safari 'off the ground' for new axle. SafariFaye Axles 9 03-18-2012 04:16 PM
What is fair sales price for 2012 Sport 16' lubelg Dollars & Cents 10 03-17-2012 07:47 AM
Anyone Near Cass Lake to Look at An Airstream for me? Mary Burris Dollars & Cents 6 03-16-2012 04:13 PM
