Old 01-26-2015, 07:17 AM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Replacng lexan window rock guard
I would like to replace the warped center section of the window rock guard on my 07 Classic. I can see how to remove the frame, but how di I remove and replace the existing lexan? It appears that it is longer and wider than the track that it is retained in. Before I remove the spline I want to make sure I can remove and replace the lexan.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 02-08-2015, 02:56 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hi I am not sure about your removal installation process as I don't have rock guards on any of my trailers but being a sign lady I know our warping is likely due to the piece of Lexan being cut a bit to big and not giving it any room for the expansion/ contraction that all plastics go through. I would recommend reducing the cut size slightly next time.
thesignlady is offline   Reply With Quote
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Source for Replacement Lexan for Rock Guards overlander63 Rock Guards, Segment & Window Protectors 39 11-01-2010 05:48 AM
Lexan window rock guard crispyboy Rock Guards, Segment & Window Protectors 4 01-31-2008 10:57 PM
Window Rock Guard balrgn Rock Guards, Segment & Window Protectors 6 10-30-2004 04:00 AM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
