Old 06-03-2019, 09:28 AM   #29
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Instructions valid regardless of glazing material
Peter,
Of course you are correct, your very detailed instructions are quite helpful regardless of whether one selects plexiglass or polycarbonate. Thank you!
If it were easy, the PO would have done it.
JRF0st3r is offline   Reply With Quote
Old 06-04-2019, 06:29 AM   #30
dznf0g's Avatar
Oswego , Illinois
Peter, thanks for the write up....pretty straight forward. One question....when you are using the old corner segment plexi for a pattern, does it want to flatten out easily, or is there a trick to accurately marking out on the new sheet?
-Rich-
Old 06-04-2019, 01:16 PM   #31
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
I found if they are very old, they will break when you try to flatten them. But the broken pieces are still sufficient to use as a good template. If you are concerned about accuracy, trace the removed curve panel on a piece of thick paper first.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-04-2019, 01:58 PM   #32
dznf0g's Avatar
Oswego , Illinois
Gotcha, thanks. Excellent write up.
-Rich-
Old 06-04-2019, 03:09 PM   #33
2007 22' International CCD
Replacing your plexi glass Rock Guards / Stone Guards
An easy tip to facilitate tracing a curved object.
Put the paper on the convex (outside of the curve) side if the material. Cut a few square ‘windows’ in the paper so you can put blue painters tape over the windows to hold the paper in place as you use a pencil to accurately mark the edge of the old one.
Then carefully peel the paper off, trim along the line carefully, and stick it down on the new material. Mark and cut just outside the line to make the new sheet.
Trick taught to me by a guy named Andy, who used this method to seamlessly cove vinyl floor covering up the walls. He claimed to have invented the technique, and he and his tools were old enough for that to be true.
RIP Andy, you were a true craftsman! The job he did for us years ago looked like the material had grown there.
rmkrum is online now   Reply With Quote
Plexi front window Stone Guard frjeff Rock Guards, Segment & Window Protectors 37 04-19-2019 11:17 PM
*"unused clear plexi-glass panels (6) from my 2009 25 ft FB ocean breeze buffet breez Airstream Classifieds 0 09-15-2015 04:34 PM
Replacing (plexi) glass in '69 Safari fotochop Windows & Screens 17 03-18-2008 06:43 AM
Lower rock/stone guards davidz71 Rock Guards, Segment & Window Protectors 12 01-24-2008 10:11 PM
Plexi or Glass? rasmuw 1959-69 Tradewind 4 08-17-2007 06:02 PM
