Old 01-18-2015, 06:58 PM   #1
1998 30' Excella 1000
Livingston , Texas
Repairing Window Rock Guard
I have a couple of small diameter (1/2") radial cracks from two rock impacts on my window rock guards. They have been stable for a long time. But I now do not like the way they look. Has any one ever tried using the automotive windshield chip repair kits on such cracks? I know they are for glass and not plastic, but was just wondering if they might reduce the visibility of the cracks.
Siegmann is offline   Reply With Quote
Old 01-18-2015, 08:04 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I doubt the windshield technique will work. Plexiglass acts much different than glass. I have one also and have given it some thought. Mine also has been stable so I haven't messed with it but I was going to drill a very small hole at each end of the crack and then with some epoxy and reinforced tape overlay it in hopes of preventing it from expanding. But I have not noticed any extension of the crack. Haven't seen any discussion here for guidance either. So maybe we both can learn from others.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-18-2015, 09:45 PM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Just a thought... I purchased a sheet of .063ga aluminum to replace the missing rock guard on my Sovereign. After I get it trimmed to size and radius bend the edges, I plan on laying out the letters AIRSTREAM across it and drilling very small holes around each letter and backlight it with amber LEDs. I will polish it and clear coat.
Just a little razzle dazzle during night trips too.
I thought about going with the original plastic, but have yet to see a guard that holds up over time. Aluminum is what AS should have used from the start, IMHO.
If you aren't worried about aesthetics you could epoxy a similar shade plastic to the inside of the guard. Also, with radial cracks that tend to grow, you can arrest them by drilling a hole at the end with a small drill bit. A hot paperclip works too.
Hope it works out like you want it to.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 01-19-2015, 05:01 PM   #4
Livingston , Texas
Navy, thanks for the comments, but it is the aesthetics that I am trying to correct. The radial cracks have been stable for years, I'm just interested in making them less visible.
Old 01-19-2015, 09:10 PM   #5
Rolland's Avatar
1967 30' Sovereign
Chiefland , Florida
I cut one corner of my rock guard, removed the old plastic, replaced it with a silver tinted plexiglass cut to size, then covered everything except the corner with wet towels, and heliarced welded the corner. I used silver silicone to hold the plexiglass in place. I don't know what year yours is, but mine is a 67, with a fairly small window in front.
Rolland is offline   Reply With Quote
Cheap Front Window Rock Guard Hotlead Windows & Screens 5 08-14-2019 09:45 AM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
window/corner rock guard installation jlarson Rock Guards, Segment & Window Protectors 2 06-05-2005 09:00 AM
Window Rock Guard balrgn Rock Guards, Segment & Window Protectors 6 10-30-2004 04:00 AM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
