Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 05-06-2009, 02:49 PM   #1
Uberphotos's Avatar
Profile:  1968 22' Safari
Kalamazoo , Michigan
Remove '68 Latch for Rockguard
Okay...So my new rockguard is a little larger than the old one...Does anyone know how to remove the black latch at the bottom? (see pic)
I popped one of (it's held on by two rivets) however, I can't figure out how to take it apart so I can re-attache it...It like a frickin' puzzle
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 05-17-2009, 10:35 AM   #2
fall city , Washington
latch
On the bottom side of the movable latch there should be a small hole you
could insert a pick to release a clip to slide the lever off. I noticed 3’’ to
the right is the original mounting location and wear marks for the draw
type latch. Vintage trailer carries them and the original rock guard.My
trailer has the original still on it and I was looking to install a new one from
vintage. Hope this helps. Barry
finnelly is offline   Reply With Quote
Old 05-17-2009, 12:43 PM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
That looks like the latch Airstream used to hold the screen door to the main door. If it is, they are pretty much single-use. That is, if you try to pry the top piece off to get at the attaching screws or rivets, the little plastic slides will probably break off.
Originally the rock guard had a pair of rubber grab handles to hold it on, and the new one should attach the same way.
Old 05-17-2009, 08:33 PM   #4
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
IF you are very gentle with it - it can be taken apart and put back together. I've done it several times (when I thought there was no way to find them anymore) and haven't lost one yet. The ears may break off but - slide it all the way to the open position and from the rear gently pry up and to the side. Watch it as it comes apart - it goes back the same way...
OHIO - WE ARE THE MOTHER SHIP
Gary
Tradewind Rockguard Installation qjktx Rock Guards, Segment & Window Protectors 17 08-02-2007 12:02 AM
Rockguard fastener repair ? Davis Rock Guards, Segment & Window Protectors 0 06-22-2007 06:15 AM
fabricating a rockguard for a 67 TW JimC Rock Guards, Segment & Window Protectors 2 10-14-2003 07:24 PM
Rockguard tmeagle1 Rock Guards, Segment & Window Protectors 12 04-02-2003 08:59 AM
New rockguard installation davespann Rock Guards, Segment & Window Protectors 0 03-02-2003 07:16 AM
