Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 04-02-2009, 03:04 PM   #1
Senshi's Avatar
Profile:  1980 25' International
Napanee , Ontario
Question Rear window restoration - 1980 International
The rear window on my '80 International is plexiglass. A PO has covered it with a frosted (mactac?) film. Obviously this was done many years ago as it has dried, cracked and looks ugly.
Because the window is plexi I cannot use a heat gun on it. The film is so hard and dry that scaping it off scratches the surface.
1. Is there a solvent that can be used to remove this that will not damage the plexiglass?
2. If not I want to replace the plexiglass. This window hinges at the top but there are no visible hinges. When the brackets that open and close the window are removed will these window frames come off simply by lifting them higher?
3. I cannot see how the front and back of the window frame (that holds the plexiglass in place) is held together to hold the plexiglass. How is the plexiglass changed on these?
Lots of questions folks. Your help will really be appreciated.
Senshi is offline   Reply With Quote
Old 04-02-2009, 03:33 PM   #2
Profile:  Corona , California
Glass replacements are available.
You might check all the other window gaskets, since the original owner did a less than desireable replacement.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 04-02-2009, 03:44 PM   #3
Senshi's Avatar
Napanee , Ontario
Andy,
Were those windows originally glass?
Old 04-02-2009, 03:56 PM   #4
Andy,
Yes.
Airstream has never used plastic windows, in production. They did in an old wing window replacement only.
Andy Rogozinski
Inland RV Center
Corona, CA
restorable 31 ft airstream international / rear master eBay Watch Airstreams on eBay 0 03-07-2009 05:20 AM
help ID-ing this 1980? International zoeb nj 1980-1984 International 9 05-28-2007 09:27 PM
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
1980 International stanm Member Introductions 0 03-25-2007 08:44 PM
1972 29' international restoration. kmandaj Member Introductions 2 12-29-2006 08:19 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
