Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 10-15-2008, 02:45 PM   #1
BLUEBELL
Profile:  2007 25' Safari FB SE
MACON , Missouri
Plexiglass looks warped
Just got home from short trip and we have 2007 Safari and the plexiglass that actually covers the glass looks warped. It is the middle section not the curved sides. One half of it looks flat and the other looks pushed in or not flat. You can put your hand on the under side of it and push it out flat. That is the best way I can describe it. Any way we did not hit anything. It is on the back side over the hitch. Anyone have any ideas as to what might have caused this. Did see one in the campground where we stayed that looked the same, should have asked the guy what happened to his.
BLUEBELL is offline   Reply With Quote
Old 10-15-2008, 02:59 PM   #2
sd90mac's Avatar
Profile:  1974 31' Sovereign
lost , somewhere
Hi Bluebell,
Could you please post a picture so we can see it.
Thanks Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 10-15-2008, 03:06 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
They never are perfectly flat. It's fairly normal for the reflections in that panel to show a small bit of wave. Is it warped more than a quarter inch? Ditto on pictures.
Can we assume the frame is still flat?
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
Old 10-15-2008, 03:14 PM   #4
BLUEBELL
MACON , Missouri
Plexiglass warped
It was flat before we left home. I don't have any pictures right now and I am not sure you could appreciate it in a picture. It is not the easiest to see, it is not a big indention and you can really see it better from the side when you look across it, but you can feel it. We are taking it in to BT camper sales in St. Louis to see what they think, but don't know how it got that way. Maybe wind resistance or something.
Old 10-15-2008, 03:57 PM   #5
Profile:  1998 28' Excella
Dolores , Colorado
Our middle section is the same way. It is not enought to write home about but you can definitely see the warp. I figure it is primarily from wind reistance. I did notice that the rubber spline used to hold it in is dropping out of the groove and I need to check that out.
FCU
#10105
Air # 28748
dogpound is offline   Reply With Quote
Old 10-15-2008, 05:10 PM   #6
I've replaced a broken lexan panel in the rockguard on my Argosy. Just push it back in with the dull blade of a screwdriver. If you remove the spline be sure to push in the direction of the already seated part as you insert it. Otherwise it will stretch and you'll have too much when done and the tension will pull it out again.
BobStream
Cleaning Plexiglass without scratching pagoff Cleaning, Stripping & Polishing 11 08-28-2007 05:38 PM
Warped door 91 Excella mudmuffin Doors & Locks 6 08-01-2006 08:14 PM
Warped Tambour Doors McNanny Cabinets, Counter Tops & Furnishings 4 04-11-2006 07:05 PM
Warped Door? Rivetedude Doors & Locks 8 05-11-2005 03:02 PM
Warped door Baja Bound Doors & Locks 9 08-28-2003 07:42 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
