Old 07-09-2017, 05:48 AM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
Plexi front window Stone Guard
Mu subject stone guard is scratched and shows a PO club number into the plexi. I do not like the idea of spending many hundreds to buy a new assembly.
Could this be painted or somehow tinted (perhaps both sides) so as to not see this? I do not care if I can see through it as it will always be opened when parked.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 07-09-2017, 06:03 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you're mechanically inclined, you can simply buy a piece of smoke color plexiglass, open the rock guard (off the trailer), and replace it. It should cost much less than a new center rock guard.
Old 07-09-2017, 06:58 AM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Check classifieds
Here is a set posted this morning
Maybe you can work something out with this guy.
http://www.airstreamclassifieds.com/...ma-rock-guard/
GMFL is online now   Reply With Quote
Old 07-09-2017, 07:09 AM   #4
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
I have a 1989 AS Excella 29. If yours would fit my unit, I would be pretty interested. Perhaps we could compare dimensions?
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 07:13 AM   #5
Well Preserved
1993 21' Sovereign
The ad is for a "ISO" rock guard. He doesn't have one, and is looking for one.
Old 07-09-2017, 03:02 PM   #6
2016 30' Classic
Glenwood Springs , Colorado
Try Plexus
If you go to a motorcycle shop and buy some Plexus. It's used to clean and polish helmet wind screens. It might work. I've had great luck with it. I just cleaned my stone guards with it. Good luck
rstull12 is offline   Reply With Quote
Old 07-09-2017, 03:05 PM   #7
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
I have tried Novus (all three strength levels) and it cleans and polishes fine. But, it does not remove the scratches nor the white appearance in the plexi.
I have used both Plexus and Novus on my cycle windscreens and they worked quite the same.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 03:38 PM   #8
brokeboater's Avatar
2003 25' Safari
High Springs , Florida
I was wondering how you were doing with your 29. I'm still searching but my white box will do until the right rig pops up.
I replaced the plexi in my first Airstream. A few pop rivets and screws, a little caulk, some sailor talk (well, maybe not you), and you're good to go. Mine was about 1/2" over half a full sheet. I went to a glass supply place and they cut it for me, not the rounded corners. I did the corner cuts at home with a jig saw. I was able to sell both drops on Craigslist so my cost wasn't that bad. It came out just fine.
ID:	289071   Click image for larger version
brokeboater is online now   Reply With Quote
Old 07-09-2017, 05:01 PM   #9
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
Still toying with all the suggestions and ideas. My local (tiny town) auto glass shop will only sell me a whole sheet. That puts it up near the cost of a new one from AS.
So, looking at painting with Krylon's Fusion spray paint. Not sure it would match, but it would look better than currently.
Good luck in your AS quest!
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 05:14 PM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
To add further confusion:
If you have any choice at all, you don't really want Plexiglass. You want Lexan. The difference in strength is significant. I have no idea which one JC supplies on a replacement order.
uncle_bob is online now   Reply With Quote
Old 07-09-2017, 05:16 PM   #11
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
Hi
Yes, I'm sorry. I meant Lexan in my questions.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 05:33 PM   #12
2003 25' Safari
Yes, mine was Lexan also. I live in a small town also. Even the bigger town I'm close to didn't have anything. I ended up buying mine 200 miles from home when I was there on other business. I had to buy a full sheet also and the place cut it to order. Apparently Lexan is hard to come by in small towns because, like I said, I sold my cut off drops proportionally cost wise to the whole sheet and the folks were very glad to get them. By picking it up when I was in town on other business and selling the drops it kept my cost reasonable.
Old 07-09-2017, 06:19 PM   #13
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
On EBay you can get partial sheet sizes of dark lexan 1/8" or whatever your after shipped to your door
AlinCal is offline   Reply With Quote
Old 07-09-2017, 06:20 PM   #14
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
Thanks.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Cracked Plexi Rock Guard Roadtech Rock Guards, Segment & Window Protectors 40 08-28-2016 08:23 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Stone Guard Window Gaskets SteveSueMac Windows & Screens 4 08-27-2014 07:10 AM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Window Stone Guard What to do? 05ModPod Rock Guards, Segment & Window Protectors 30 08-31-2006 09:49 PM
