Old 08-16-2015, 02:35 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
New problem
Just found this. Center Click image for larger version
Name:	ImageUploadedByAirstream Forums1439757351.058003.jpg
ID:	245614Upper bracket for fwd rock guard. Rivets are pulling out and skin is cracked. Something else to fix when I get home.
MICHAEL
Old 08-16-2015, 02:55 PM   #2
Originally Posted by AWCHIEF View Post
Just found this. Center Attachment 245614Upper bracket for fwd rock guard. Rivets are pulling out and skin is cracked. Something else to fix when I get home.
Michael.
That photo indicates one or more of the following.
Unbalanced running gear, excessive rated hitch bars, excessive rated tow vehicle.
Installing a small plate over that area and then remounting the bracket using 3/16 pop rivets, will do the job. Make sure you seal the pop rivet heads.
Old 08-16-2015, 03:29 PM   #3
Central , Mississippi
I had the same problem several years ago on my 34'.
I made a circular patch, rotated the rivet holes 45 degrees and used lots of sealant. Tens of thousands of miles later and it's still holding fine. Click image for larger version
Name:	ImageUploadedByAirstream Forums1439760546.961482.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Condensation problem...big problem MonaxLisa General Repair Forum 16 10-31-2010 10:00 PM
New Atwood water heater old Bowen door vent problem 63air Electrical - Systems, Generators, Batteries & Solar 0 08-22-2005 02:56 PM
The New Look! = Prompt Address to Problem winner Forum Admin, News and Member Account Info 2 05-30-2004 09:37 AM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
New Airstream - Air conditioner/Furnace problem mariffe Electrical - Systems, Generators, Batteries & Solar 12 04-16-2003 04:26 PM
