Old 11-22-2015, 10:03 AM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Need Segment Protector Molding
I posted this in a thread by a different name and got no response, so I'm trying again with a more descriptive title.
The surround molding on my curbside stainless steel segment protector got cracked by the PO in a hookup incident. Unnoticed by me the crack progressed until the molding separated at the crack resulting in the protector vibrating in the wind while towing. It has abraded the segment now, looks like it was sandblasted.
It seems silly to have to buy a complete protector when all I need is the 1/4" C-shaped aluminum molding surround. Does anyone know of a source? I have not been successful with Google searches.
As an alternative I suppose I can try to have it welded, but I don't know if that would hold, and I don't want to end up with the molding welded to the stainless.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 11-22-2015, 10:25 AM   #2
Tuco's Avatar
1988 32' Excella
Ojai , California
Al, some pictures might help since I have no idea what is being discussed.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 11-22-2015, 12:53 PM   #3
Video wont play, but you can see the crack.
S/OS #004
Old 11-22-2015, 01:09 PM   #4
Tuco's Avatar
1988 32' Excella
Ojai , California
By the looks of this you should be able to have it welded and textured to match. Ask a fabricator if they can reinforce the back of the guard to prevent further cracking. If he uses the same rivet points it should be seamless. Some flat stock aluminum should do the trick (say 1/8"), but let the fabricator decide. A good place to find someone to do this would be at a small airport.
GL
Dave & MJ
Old 11-22-2015, 01:22 PM   #5
Whoa - the video (taken with an iPad) won't play on my iPad but it does (one time) on my Win 8 laptop.
Thanks. Didn't think about the airport thing.
Al
S/OS #004
Old 11-22-2015, 02:50 PM   #6
The reason I couldn't find it.....
was I was looking for c-channel and it is j-channel. I talked to a friend about repairing it and he said he could weld the molding but we'd have to take the protector off the trailer. When I went to remove the protector, I discovered that when I noticed the damage I didn't look close enough. Several things contributed to the vibration that cracked the molding. The corner rivets at the hinge were loose. The PO's repair drilled out several of the rivets that fastened the hinge to the body and replaced them with screws; the top screw was loose. The 1/4 turn fastener at the bottom on the curbside was broken.
I replaced the corner rivets, clamped the molding with a pipe clamp and drilled and riveted across the crack. In retrospect I should have put in a backing plate, but I don't have rivets long enough so that's a problem for another day.
So now I'm looking for a replacement standoff base for the 1/4 turn fastener. I don't think it is a Dzus, but I'm still looking. If anyone knows what it is please let me know.
Al
S/OS #004
Old 11-22-2015, 03:22 PM   #7
Found it, sort of.....
The fastener is made by Southco. I'll try to find some locally, and if no luck I'll call some dealers.
Al
S/OS #004
Old 11-22-2015, 04:01 PM   #8
Found it
I have seen Aircraft Spruce listed as a source for aluminum on here. Turns out they have the Southco fasteners. Just a plain base is inexpensive. But to keep vibration down, AS uses one with a rubber vibration washer. I went ahead and ordered two (big spender) and will replace both since one failed. Here is what I ordered. Someone else was looking for some a month or so ago, maybe not for the same application.
SOUTHCO RECEPT 82-35-306-10 9.850
Al
S/OS #004
Old 11-22-2015, 08:49 PM   #9
Tuco's Avatar
1988 32' Excella
Ojai , California
Wish I had gotten back online sooner I could have saved you some time. I have noticed that several parts on our Airstream's are from the aircraft industry. The 1/4 turn fasteners with rubber mounts were used as cowl hold downs on several models. Some of the rubber strips used on the interior are also from aircraft. Glad you found Aircraft Spruce and got what you needed. Show us some pictures of the final repair.
Dave & MJ
Old 11-23-2015, 10:17 AM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I also had a broken molding in about the same area. The local dealer gave me a throw-away damaged protector with a good top half molding. I replaced my broken molding with the salvaged part with a splice in an inconspicuous place on the rear of the protector, at the lower attachment.
I found that removing the old molding was very difficult because of the way everything had been riveted together when the protector was first built. I had to use a Dremel grinder in several spots to get things apart without doing more damage.
The final result looked pretty good, but with all the labor, I would just buy a replacement protector next time around.
John W. Irwin
WBCCI #9632
Segment Protector install equigley 1969 - 1973 Safari 3 02-07-2015 07:05 AM
Segment protector ticki2 Rock Guards, Segment & Window Protectors 4 10-21-2008 05:53 PM
Segment Protector Corrosion chaunceyboy Ribs, Skins & Rivets 27 06-14-2007 07:05 PM
Need a source for Segment Protector latch R&SZinser Rock Guards, Segment & Window Protectors 9 10-04-2006 07:47 PM
?? Lower segment protector fit ?? driftwood Rock Guards, Segment & Window Protectors 1 03-07-2005 04:09 PM
