Old 04-12-2015, 05:41 PM   #1
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
My Hook Things Won't Hook
Today was day one of Spring in NJ. I decided to wash and wax the Airstream. I am owner 3. One and two never unscrewed or unlatched the window protectors or bannana wraps to ever wash or wax. Everything was going well until I could not hook/latch/turn the hook type part that holds my left front window protector closed. It goes into a gasket like round hole and it just won't stay tight. Thankfully my other side is fine, which is how I know I need to do about a half turn to close it. My front window will keep side closed, but I know this needs to be fixed.
- thick washer part on Airstream is not screwed into trailer, but perhaps riveted? How do I fix this?
- Can I drive the trailer with it closed and held in by front window?
-Does it have to be repaired at dealer or can an RV repair fix it?
Thank you for you help with this matter, I am hoping it is something I cam fix myself. Susan
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 04-12-2015, 06:15 PM   #2
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
You can fix it yourself, go to one of the on-line suppliers that sell Airstream parts. The part you need is called a "Zues fastener" they ar commently used in light airplanes.
http://airstreamsupply.com/New-Airst...ent-protectors
Scroll down on that page to:
RUBBER RECEPTACLE, #82-35-306-10 STONEGUARD/WRAP PROTECTOR
Rubber Receptacle, #82-35-306-10 Airstream Rockguard
Turn fastener stud
Turn fastener stud for Airstream Rock Guard ..
Get both parts, they are easy to install....
Good luck,
Larry
Larry C is offline   Reply With Quote
Old 04-12-2015, 06:16 PM   #3
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
If it was me I wouldn't drive with it un- latched. If it flies open on the road it could cause lots of damage. I had to replace one on our last AS and it wouldn't fit either. I'm not telling you to do this (and it may not help yours) but I took the protector off the AS and bent the bracket that attaches to the AS.
Landrum is offline   Reply With Quote
Airstream - How Can You Get Some Things so Right....and Other Things so..... Fly at Night Our Community 19 12-08-2013 07:44 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
Lower mount on shocks won't hook up to new axle 1963tradewin Axles 8 09-01-2007 10:42 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
I won, I won!!!! till Off Topic Forum 13 11-28-2004 07:17 PM
