Old 12-17-2005, 06:30 PM   #1
cosmotini's Avatar
1963 24' Tradewind
Saint Louis , Missouri
Images: 83
Mud Flaps Revisited
Hi all,
I've been checking into the Enkay adjustable mud flaps for the F-250 and came across these.
http://www.vaughnboats.com/Shindigger.htm
Anyone have any knowledge or experience with them? How do they compare with the Enkays?
Also, it looks like the Enkays are the same price no matter where you get them from. Does anyone know of a dealer with better prices? All of the ones I checked out have $229 for the non-dually set.
Dennis
cosmotini is offline   Reply With Quote
Old 12-17-2005, 07:24 PM   #2
_
howdy cosmotini
best price i located on the enkays' was here.......
www.cabelas.com
Rock Tamers™
Item: IF-521664 Price: $189.99
http://www.cabelas.com/cabelas/en/te...equestid=92383
of course i found this after placing my order for 225$...
natually.
Old 12-17-2005, 07:39 PM   #3
cosmotini's Avatar
1963 24' Tradewind
Images: 83
Thanks 2air!
google didn't find Cabelas
Old 12-17-2005, 09:39 PM   #4
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I built my own.
square stock was $8.00 from metal shop. 24"wide flaps were $4.00 each. Can of black rustoleum paint $4-5.00. Two galvanized 2"x2" angle brackets $3.50. Two 2"x1/4"galv. bolts and ten self tapping galvanized sheet metal screws to hold the flaps.
The angles were drilled to match the bolts that hold the receiver, bumper assembly from the bottom.
Takes a little drilling, painting, measuring for height. Cut the flaps to length with my table saw.
Only disadvantage, it is made specifically for my 2003 gmc on width & height. Looks very similar to the Vaughn except square stock with flaps is bolted to the angles about six inches from outside edge of bumper.
Folks in my WBCCI unit usually make their own.
wingfoot321 is offline   Reply With Quote
Old 12-17-2005, 11:28 PM   #5
1992 34' Limited
Falls Church , Virginia
Wingfoot - Photos???
Wingfoot -
Sounds like a perfect "Holiday Do-it-Yourself" project.
Photos???
Also, where did you get the flap stock. Sounds like Heavy Duty if you had to break out the table saw for the cutting.... Square stock was aluminum? HD, Lowes?
Thanks, and looking forward to photos if you got em!
Axel
SilverToy is offline   Reply With Quote
Old 12-18-2005, 06:41 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
axel
i made my own too.
you can see them near the bottom of this thread.
http://www.airforums.com/forum...ight=mud+flaps
john
you call them ferrets, i call them weasels.
Old 12-18-2005, 06:59 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Okay...curiosity question here,...My "new" truck has the big mudflaps right behind the wheels, should I still add the monster flaps at the back? and how effective are the "grass skirts" style flaps like you see on the UPS trucks and big MoHo's?
Aaron
WBCCI #XXXX AIR #2495
Old 12-18-2005, 07:13 AM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
aaron
i have both wheel well flaps, plus the ones i made.
i still get rock dings, just not as many. i think some of them come from vehicles going the other way.
john
Old 12-18-2005, 07:23 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Originally Posted by john hd
aaron
john
that is a given...my AS looks like it has been sand blasted around the front quarters...beauty marks? I have the monster flaps on my truck...big rubber and stainless that hang with in about 3-4" of the ground, I guess I will give them a try first...then if necessary build the big one
Aaron
Old 12-18-2005, 02:52 PM   #10
_
hi wahoonc and others
i really do like the enkays. the basic truck flaps don't offer complete coverage so for me adding the nks do....after fitting i drove in the mud lookin for gaps in coverage, adjusted the nks to fine tune the gaps.
the flaps cosmotini links in the first post appear to mount, such that, no hitch/receiver mods are needed.....for the nk's the receiver must be longer or the bracket modified...others have posted photos and info on this modification.
i suspect the really large metal and rubber flaps wahoonc has, provide enough coverage, and adding another set would not be cost effective....given the trailer is already sandblasted down low....now if it was ever repaneled or traded for new......
there are several threads on rock tamers, mub flaps and so on, in the archive. lots of nice homebrew'd and tweaked versions.
here's the thread i like (i wonder why) and it does show how each set of flaps can "catch" different items (caution bad taste/humor ahead).....
http://www.airforums.com/forum...nth-18538.html
cheers
2air'
Coast To Coast Rv Resorts ALANSD On The Road... 31 07-20-2018 12:27 PM
Roadwing removable mud flaps Kistler Our Community 4 03-20-2003 04:39 AM
Mud flaps on an A/S Silvertwinkie Our Community 8 03-10-2003 06:29 AM
Mud flaps on an A/S MH ALANSD Airstream Motorhome Forums 3 03-10-2003 05:58 AM
Not an Airstream but interesting dienst1 Airstream Motorhome Forums 11 09-15-2002 11:16 PM
