Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 10-09-2014, 11:56 AM   #1
coloradopete
coloradopete's Avatar
1988 25' Excella
Montrose , Colorado
Manufactured and Installed Window Rock Guards
After replacing the front driver side curved window assembly, I decided to manufacture and install rock guards on both front curved glass windows on my 1988 25' Excella. I completed the installation just yesterday and the guards look pretty nice. I used .062 thick, clear polycarbonate sheet material for the guards . The sheet size that I used is 2' x 4'. I designed and manufactured 4 mounting brackets for each window which I attached to the window frames with pop rivets. The guards are held in place with # 10-24 stud screws and acorn nuts. I made the mounting brackets of aluminum bar stock, .375" thick x .750" wide x 2.500" long. The mounting holes in the polycarbonate guards are lined with brass grommets. I had never machined polycarbonate material before and was a little apprehensive in doing so, but found it to be easy to saw and drill with sharp tools. I say again "sharp tools". Anyone interested in this project may request from me, detailed drawings of the bracket assembly.
ID:	223997   Click image for larger version
coloradopete is offline   Reply With Quote
Old 10-09-2014, 02:57 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Nice job Pete. Did you need to heat and bend the material or was it flexible enough on it's own ???
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-09-2014, 03:29 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Very nice job!
Bob Martel
WBCCI# 5766
Old 10-10-2014, 03:16 PM   #4
coloradopete
1988 25' Excella
Montrose , Colorado
No. The material is thin enough to form around the window curve but firm enough to resist deforming during travel. However it can be heated and formed I am told.
Old 10-10-2014, 04:32 PM   #5
Hotlead's Avatar
1971 23' Safari
Nashville , Tennessee
Nice !
I couldn’t fix your brakes, so I made your horn louder…..
Hotlead is offline   Reply With Quote
Old 10-10-2014, 04:51 PM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Nicely done!
Skatiero is offline   Reply With Quote
Old 12-14-2014, 06:03 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I suppose you have had a couple of miles to run your install. How are they holding up? any issues with wind vibration?
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-08-2016, 04:00 PM   #8
coloradopete
1988 25' Excella
Montrose , Colorado
Rock Guards for front windows
I apologize to all for not posting the result of my effort to construct window rock guards for the curved windows on my trailer. The construction went well but the result was not good. The material was too thin and was not resistant to the wind during travel. I have not made further attempt to correct this problem but did consider adding a metal support rail around the edge of the polycarbonate material for strength and also add a few more mounting brackets .
Window rock guards.... warp Gator113 Rock Guards, Segment & Window Protectors 13 03-09-2015 05:20 PM
1958 Airstream Flying Cloud 22 Ft. Travel Trailer -Manufactured in California eBay Watch Airstreams on eBay 0 01-09-2012 05:30 PM
Owner's Poll: Rock Guards and Segment Protectors SmokelessJoe Rock Guards, Segment & Window Protectors 3 11-21-2007 07:32 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
Walbernized the rock guards and... Kistler Our Community 12 03-10-2003 07:12 AM
