Old 02-11-2014, 12:22 PM   #1
Just Ginger's Avatar
1978 Argosy Minuet 6.0 Metre
Savannah , Georgia
Making Rock Guards for Minuet
Since I learned much from the forums, I have bought Common Sense Fasteners (from NW Tarp & Canvas) and have just now drawn out my pattern to make my own rock guards.
I have until the first weekend in April to complete the two corner panels; that's when the April Fool's Rod Run takes place at Twin Oaks Park in South Georgia.
Thanks for the posts and information. Suggestions I read have been very helpful in my figuring out to do this. I'll post later on my success.
Ginger
Just Ginger is offline   Reply With Quote
Old 03-13-2014, 03:43 PM   #2
Savannah , Georgia
I just finished my rock guards for my 1978 Six-Metre Minuet (The Dragon). The project turned out to be a bit more tedious than I had anticipated, but, of course, the second set would be easier now that I know how to do it; design & build at the same time is harder. If I ever have to do it over, I'll make a couple of modifications.
I entered the first post in mid-February, so I see that it took a month, but I worked on some other things along the way. I had to do some thinking about it. The Common Sense fasteners were the major expense; I used twenty per window, and at $2.40 each that was almost $100. Everything else was from stuff I had on hand. I used one-inch styrofoam panels for the inside padding, red broadcloth for the outside (like canvas but not as heavy), and an industrial material from a foam mattress for the inside fabric.
I'll post pictures tomorrow, just in case anyone is interested.
Ginger
Old 03-15-2014, 12:33 PM   #3
Savannah , Georgia
As soon as I figure out how to post a photograph of my rock guards, I will do so.
Old 03-15-2014, 12:45 PM   #4
Savannah , Georgia
Old 03-15-2014, 12:46 PM   #5
Savannah , Georgia
Old 03-15-2014, 01:14 PM   #6
1981 31' Excella II
New Market , Alabama
They look good but are the snaps that hold them on a potential for leaks?
Perry
Old 03-15-2014, 01:56 PM   #7
Savannah , Georgia
Hello, Perry,
Good question. I was thinking about that while attaching the turn posts. I decided to just screw them in for now, until I made sure the plan worked, and next I'm going back into each one, unscrew it and put a dab of sealer on each, and then rescrew them. With my driver, I can do that sealing job pretty quickly. Thanks for the mention.
Ginger
Old 03-15-2014, 02:10 PM   #8
1981 31' Excella II
Sounds like a plan.
Perry
Old 03-16-2014, 09:47 AM   #9
Savannah , Georgia
The plan seems to be working. I'm about ready for the 100-mile trip to the April Fool's Rod Run at Twin Oaks Park in Hoboken, GA. The Dragon spent ten years as my guest house before I decided to make it roadworthy again. I've reworked the interior, and it's comfortable and roomier now. I took it for a neighborhood test drive a couple of weeks ago (after repacking the bearings), and it followed nicely. The Turtle (1965 Shasta 13') is staying home this year.
Old 04-02-2014, 10:59 PM   #10
Athens , Georgia
Ginger,
I just bought an old Minuet from a fellow in Americus. This is a great idea, I wonder if they will be stiff enough to protect against rocks, though? What do you think?
MIKO92 is offline   Reply With Quote
Old 04-06-2014, 08:51 PM   #11
Savannah , Georgia
I just returned from The Dragon's first outing since the remodel and making the rock guards. All worked perfectly, and I used a styrofoam sheet that I scored to bend.
Old 04-07-2014, 09:58 AM   #12
1981 31' Excella II
Do you have any information on the fasteners you used?
Perry
Old 04-08-2014, 07:45 AM   #13
Savannah , Georgia
Hello, Perry,
I got the Common Sense fasteners from Jim Watt at Northwest Tarp & Canvas in Bellingham, WA. Number: 360-296-2321. He had the best price I could find and is a totally pleasant person.
I got 40 sets, including the screws for $90. I designed the guards for twenty per window. I could have used fewer fasteners, but I wanted to make sure everything was securely attached.
If you need anymore information about what I did, just let me know.
Ginger
Old 07-26-2014, 07:30 AM   #14
Savannah , Georgia
I got this message through email from MIKO92 but couldn't access it here, so I'm posting my reply in case anyone else wants to know: "Ginger, Did you put the common sense fasteners on the window frame of the Dragon or in the skin of the trailer? Thanks for your posts regarding the covers!"
Hello, MIKO92, I attached them on the skin just outside the window frame. Done again, I would put just a tiny bit more space between the fastener base and the edge of the window. Across the bottom, I put them inside the band that runs horizontally around the trailer.
Ginger
Soft rock guards DKB_SATX All Argosy Trailers 8 03-15-2013 09:45 AM
Rust spots already on rock guards - 2011 Airstream wendywoods Cleaning, Stripping & Polishing 38 03-09-2012 09:34 AM
Reattaching a Rock Guard Bettye Rock Guards, Segment & Window Protectors 5 02-17-2012 07:34 PM
New grommets for my rock guards willbrackman Rock Guards, Segment & Window Protectors 2 01-01-2012 07:14 AM
TAC Illinois Rally - Starved Rock SP - May 13 to May 15 Air Apparent Other Rallies & Events 4 05-14-2011 08:58 AM
