Old 05-25-2012, 03:02 PM   #1
1966 26' Overlander
Conover , Ohio
making my own
I found a 36x48 sheet of lexan at Menard's today for $68. They had a fair amout of aluminum channel (angle and flat) I think I can make a frame out of. My hinge is about the only thing left or the original rock guard. I'm still tring to find a good (cheap) source for a pair of rubber hood tie downs for the bottom, any ideas? I am also trying to figure out how to make a pair of rods to hold the widow up?
TomE
project66 is offline   Reply With Quote
Old 05-25-2012, 03:18 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Tom, please post some pictures as the project progresses. I am going to be doing the same project soon.
MICHAEL
Old 05-25-2012, 05:02 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I think vintage trailer sells those rubber hood tie down things.. Thats where I got mine i believe.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 05-25-2012, 05:32 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Aren't those rubber gizmos the same as they are currently using? If so any dealer can probably get them.
Old 05-25-2012, 05:59 PM   #5
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Rock Guard Hold Down Latches
TomE
Try these 2.
McMaster-Carr
Rock Guard Hold Down 381021-01 [381021-01] - $9.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
tinbender is offline   Reply With Quote
Old 05-25-2012, 06:13 PM   #6
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Rubber tie downs.
I round them at Colonial Airstream dealer.
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 05-25-2012, 06:32 PM   #7
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Please post pictures, I'm planning a similar project. I have the original front window guard, but it is pretty beat up and has holes in it.
Stephanie
Old 05-25-2012, 08:47 PM   #8
Chief Ding Dong
dino242's Avatar
1966 28' Ambassador
Patterson , Louisiana
Good luck! We did this last month, and it was a quick and fun little project. Luckily, we did have hardware from the god-awful...thing.. the PO put on Ambassador. Just built a frame from some aluminum C-Channel.
dino242 is offline   Reply With Quote
