Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 08-19-2008, 11:30 AM   #1
Profile:  Carson City , Nevada
Line-X or Rhinoliner protection
I am considering applying Line-X or Rhinoliner (1/4" thick, perhaps) on the front of my Argosy to protect the aluminum from rock damage. I am also fittinga new rock guard this week.
Has anyone used a spray-on bed liner to protect the front of their AS? How well did it do he job?
Thanks.
Mike
Mike S is offline   Reply With Quote
Old 08-19-2008, 11:32 AM   #2
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Thanks.
Mike
Mike,
I know this has been discussed before. Did you try the search function? I know it looks a lot better if you can get a color to match the trailer Black looks funny.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 08-19-2008, 12:04 PM   #3
3streams's Avatar
Profile:  1962 16' Bambi
1959 30' Sovereign
Springs , Pennsylvania
My husband just had line-x done on his truck bed and for an extra $ they color matched the line-x- from a distance you can't even tell there is a bed liner- of course his truck is dark metallic green. And- line-x over rhino liner any day!!!!
April & Andy Hershberger
www.ClassicAluminumTrailers.com
WDCU Membership Chair, WBCCI #5924
3streams is offline   Reply With Quote
Old 08-19-2008, 03:59 PM   #4
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
Question, If you are installing rock guards why to you want to put on a bed liner? or are you putting it on the rock guards?
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-19-2008, 04:38 PM   #5
norsea's Avatar
Profile:  2008 30' Classic
On the road since 2000 , norseaodyssey.com
LineX/Rhinoliner and aluminum...
Thanks.
Mike
Hi Mike,
The first issue you will need to deal with is finding someone who is competent with either product AND aluminum.
Painting aluminum is difficult at best and calls for special primers that must be able to bond to the metal.
Metal preparation when working with aluminum is key.
I just had an aluminum flat bed on my truck covered with LineX; this solved the glare from the sun, slippery when wet and general abuse issues.
I searched long and hard before I found someone who had applied either product to aluminum.
Most of the people I spoke with at these shops knew that they had to do special tasks to prepare the aluminum AND apply the proper bonding agent if either was to work.
Only one told me he had someone who "knew what he was doing" who would do the aluminum flat bed prep work that involved very carefully sand blasting the entire surface. Doing work of this nature is NOT for the faint of heart. It would be very easy to remove lots of metal with a sand blasting tool. He told me they had done several this way and had no problems.
He also told me that they had decided to stop doing aluminum because of the problems they were having with the coating peeling off after a short period of time until they found the local gent who was doing the sand blasting.
I am very happy with the work they did. It cost $175.00 for the sand blasting over and above the actual primer and coating costs.
I have seen an entire Vanagon VW that was covered by one of these products in a magenta color. VERY different, but impervious to the elements and he did not have to wax it!
We are travelers with an attitude. We get to go anywhere, anytime, and have attitudes about what we see and hear.
"Travel is fatal to bigotry, prejudice and being narrow minded."
norsea is offline   Reply With Quote
Old 08-19-2008, 05:41 PM   #6
mustang's Avatar
Profile:  1986 31' Sovereign
Kent , Ohio
I would think the weight factor would also make one not consider it. Back of a truck is one thing hanging on the front of a trailer metal sweating and trailer bouncing and jarring, heat, cold expand contract, stress on body panels held on by rivits ect. I am curiouse how long it would last?
mustang is offline   Reply With Quote
Old 08-19-2008, 05:46 PM   #7
Hillbilly
Profile:  1967 28' Ambassador
Hartford , Iowa
Hi Mike,
Rino-liner is the toughest product for protection I have ever seen. Try and get an aluminum color match, they have it.
Rusty L. Sinclair
Rusty L. Sin is offline   Reply With Quote
Old 08-19-2008, 06:41 PM   #8
willyd's Avatar
Profile:  1993 34' Limited
Melbourne Florida , Springfield Ohio
I have used Rino-liner in the past and it looked great and held up better.
willyd is offline   Reply With Quote
Old 08-19-2008, 07:08 PM   #9
jpeterman's Avatar
Profile:  1972 27' Overlander
Graham , North Carolina
we had a red color put on our mowers at our golf course where I work for the floor boards and steep. It was great and really lasts.
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 08-21-2008, 09:59 AM   #10
mustang's Avatar
Kent , Ohio
I am curriouse to whether it will work in the vertical position, we know it will work in the horizontal position the weight of it self would hold it in place along with gravity. I would love to see some pictures once done and how long it will last.
Old 08-22-2008, 02:25 PM   #11
3streams's Avatar
1959 30' Sovereign
Works on the walls of the truck bed- they spray the whole thing. You can even get your rig undercoated in this stuff. It real popular around here because of all the snow/salt in the winter. We love line-x the best- had it on the last truck and it was the first thing we did to our new truck. When we get the cap in for the truck we are thinking if having the inside of it sprayed to match also.
Old 08-22-2008, 04:08 PM   #12
Airhog1's Avatar
Profile:  1975 31' Sovereign
Searcy , Arkansas
Not sure what this guy used but it didn't hold up to well!
G
Name:	Rhino Liner 001.jpg
ID:	66023   Click image for larger version
Name:	Rhino Liner 002.jpg
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 08-22-2008, 05:03 PM   #13
mustang's Avatar
Kent , Ohio
I know that but the wall of a truck bed is very different. When it is bouncing and jarring it is pushing down and on a angle inward so The only thing that could happen is a wrinkle in the middle or other side pop up. The airstream is very different nothing to push or rest down on. If it sags it will just work its way loose then fall of is what I would think?
Old 08-22-2008, 05:06 PM   #14
mustang's Avatar
Kent , Ohio
I asked about the under coat thing to up at Line X I personally think Line x is the best but, that is what makes the world go round, anyways they were hesitant because of weight and the vary reason I spoke of. Moisture and the way it bonds to the side. I will probably keep an eye out for this now
UV Protection for new A/C JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 17 03-28-2008 01:13 PM
Blow out protection Barbara Peerenboom On The Road... 11 08-12-2004 05:03 PM
Walbernize UV protection Silvertwinkie Our Community 1 03-12-2003 03:40 PM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 03:55 PM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 10:42 PM
