Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 01-31-2008, 10:37 PM   #1
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
Lexan window rock guard
Looking for a little advice here on the front window rock guard. I was thinking about purchasing one this spring but I am concerned about the fitment of the one piece guards.
The trailer I have is a 1981 Excella II - a small bodied trailer. The exterior dimension on the small body is 86.5". The larger trailers of that year are 95.5" wide accoding to the owners manual specs.
Can a standard rock guard be molded or cut down to fit my trailer size?
crispyboy is offline   Reply With Quote
Old 01-31-2008, 10:50 PM   #2
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
The PO put one on my '72 Globetrotter, I'm guessing they are similar if not the same.
Fyrzowt is offline   Reply With Quote
Old 01-31-2008, 11:51 PM   #3
Ifihadtime
Ifihadtime's Avatar
Profile:  1981 27' Excella II
Lynnwood , Washington
Crispyboy, I have 81 27', it must be the wider body. It has a rock gaurd on it and I replaced the acrylic in it last year. If you are truely 9" narower then you will have to cut it down to look right. From memory it is something that could be done if your fairly handy but not the easiest thing to do. I would think you might be able to buy one the correct size or have it modified at the factory. Unless you had an old one to fiddle with you might find your opening a can of worms to make it right, IMO.
Ron
81 Excella II "McTwinkie"
It takes hundreds of nuts to hold a car together, but it takes only one to scatter it all over the highway!
Ifihadtime is offline   Reply With Quote
Old 01-31-2008, 11:52 PM   #4
Ifihadtime
Ifihadtime's Avatar
Oh by the way, nice trailer!
Ron
Old 01-31-2008, 11:57 PM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
There is a ready made "Rockguard" that is designed to "exactly" fit your front three windows.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Last edited by CanoeStream; 02-01-2008 at 07:03 AM. Reason: Remove quoted photo repeat
Rock guard for wing window? SilverToy Rock Guards, Segment & Window Protectors 5 05-11-2006 07:59 AM
Cheap Front Window Rock Guard Hotlead Windows & Screens 4 06-30-2005 12:31 AM
window/corner rock guard installation jlarson Rock Guards, Segment & Window Protectors 2 06-05-2005 10:00 AM
Window Rock Guard balrgn Rock Guards, Segment & Window Protectors 6 10-30-2004 05:00 AM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 05:58 PM
test
