Old 04-02-2005, 06:18 AM   #1
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
I need fittings - Where?
Need to find rear mounts for lower rock guard fittings. Can anybody help?
I would be satisified with only the (4) sections of aluminum 'hat' extrusions, but the resilient mounts would be good.
I was lucky enough to find good condition used stainless steel lower rock guards and want to mount them as the factory did.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 04-02-2005, 11:24 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Are you looking for original mounts or ideas where / how to fabricate new ones?
Your pics are small, can't quite make out what you looking for.... :O\
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-02-2005, 11:41 AM   #3
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Images: 35
Balrgn, I prefer original ...
My preference is to original, although ...
The resilient mount is small and is on the lower aft corner of the guards. I believe it has a threaded insert in the middle of the round rubber that is attached to the two leg metal strap. It should come with a round head machine bolt in the mount that goes through the rock guard.
The aft upper corners is an aluminum 'hat' in cross section is total 1 1/2" wide with a 3/4" x 3/4" hat. I guess ~ 3/32" thickness.
I saw at the dealer, apparently the resilient mount isn't used anymore, just the aluminum 'hat' section installed for top and bottom attachments on new units. The 'hat' is riveted to the skin and provided with a fixed 1/2' SS bolt. Length varies from 2" to 5".
As the guard (AS calls it a 'wrap protector') hinges closed to the rear, the bolt protrudes through a hole in the guard and a cap nut secures it.
My efforts to obtain, say 18" of a compatible/similar 'hat' extrusion has been unsucessful.
NORM #3305
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Metric LPG fittings, Therm'x heater walter1 LP Gas, Piping, Tanks & Regulators 0 09-14-2004 09:27 AM
fittings John Greenlee LP Gas, Piping, Tanks & Regulators 5 07-12-2004 07:49 AM
retailers that sell flair-it fittings? Chuck Fresh Water Systems 3 07-09-2004 08:44 PM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
