Old 05-09-2010, 09:59 AM   #1
1978 Argosy 27
Lacey , Washington
Images: 8
How to mount new segment protectors?
Purchased corner rock guards (2) for '78 Argosy. I need direction and help on how to mount them to the skin of the trailer. What type of screws/rivets? to use and how to seal the screws/rivets? Are there directions on doing this?
Thanks jjusticeairstream
jjustice is offline   Reply With Quote
Old 05-09-2010, 12:18 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Bump,I would like to know too,I plan on making mine. Dave
easyride is offline   Reply With Quote
Old 05-09-2010, 12:21 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
http://www.airforums.com/forums/f227...nuet-9638.html
We did this on a minuet which meant cutting down the center section to fit the Minuets narrower body... you can prolly skip that part.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 05-10-2010, 11:42 AM   #4
1978 Argosy 27
Lacey , Washington
Images: 8
Let me clarify. These are the two segment/rouck guards that go on the front corners of the trailer below the windows. Sorry if the first post was not clear.
Old 05-10-2010, 12:30 PM   #5
Janet H's Avatar
1964 26' Overlander
Images: 90
These are called segment protectors which may help you when searching. I can change your thread title to reflect this as well...
Old 05-10-2010, 01:00 PM   #6
1978 Argosy 27
Lacey , Washington
Images: 8
Yes, please and thanks
jjustice
Segment protectors b8sfamily Rock Guards, Segment & Window Protectors 23 07-22-2016 03:53 PM
Installing the taller segment protectors.. ROBERT CROSS Rock Guards, Segment & Window Protectors 2 07-15-2016 08:59 PM
How to install segment protectors - help needed! :) 71safari Rock Guards, Segment & Window Protectors 0 09-22-2009 05:30 AM
Query on Segment Protectors TX_Streamer Rock Guards, Segment & Window Protectors 3 09-09-2009 05:30 PM
Basecamp Segment Protectors? Friday Rock Guards, Segment & Window Protectors 0 04-30-2009 03:19 PM
