Old 11-09-2013, 07:58 AM   #85
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
Just wondering if anyone has experience with a product like EcoFlaps that reduce drag and spray yet stop rocks from hitting the AS?
Link to their site:
Eco-Flaps
Old Cobra AH-1G Pilot
WoundedWarriorsFamilySupport.Org
http://www.highfivetour.com/
Snaken49 is offline   Reply With Quote
Old 11-09-2013, 08:35 AM   #86
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Originally Posted by adonh View Post
I use the Protect a Tow system on my Motor Home. It does a great job and is easy to install and remove and store when not in use. It is also available for travel trailers. Its another option
trailers
That is interesting - how long have you used it and how much use does it get? Kinda seems like with turns it would stretch it damage it etc?
PharmGeek is offline   Reply With Quote
Old 11-09-2013, 08:44 AM   #87
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
It connects with a bungee cord to points in my case on the coach and tow. The same would apply to a TV and trailer. There is a PVC device that also connects the open sides and runs across the tow bar or hitch. This prevents it from dragging during turns. I use it every time I hook up. Here are some pictures that show how it set up. gallery
Its a simple design that works and folds up in a small bag when not in use.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 11-09-2013, 09:04 AM   #88
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Adonh - standing behind TV - is there line if sight for AS to TV tires? Seems like the contraption is a bit narrow near TV?
Old 11-09-2013, 09:06 AM   #89
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Does it block a path from TV tires totally? Looks like it does but had to tell
How long have you owned? Do you have shots of it on your setup?
Old 11-09-2013, 06:49 PM   #90
dznf0g's Avatar
Oswego , Illinois
Link to their site:
Eco-Flaps
I had thought about using these on the RT hardware....but how would one cut to a custom length and have any durability of the material. I think there would be problems with breaking and fraying for the material if cut.
-Rich-
Old 11-09-2013, 07:07 PM   #91
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
My concerns as well
Old 11-10-2013, 07:54 AM   #92
adonh's Avatar
1976 31' Sovereign
I can only speak for the Motor Home version. since the wider section is connected to the Motor Home is does block path for MH tires. In looking at the gallery pictures the Trailer version has the wider section connected to the trailer and the narrow section across the length of of the rear of the TV. That would make sense due to the trailer being wider than the TV. My question would be although it would be a simple step to install the requited eye bolts to an SOB where would you install the eye bolts to the Airstream front banana wrap. On my little car that I tow with the MH I installed a heavy duty type molly bolt arrangement that has a 1/4 threaded opening in the front underside of the car on each side. I can then attach the 1/4 eye bolt when towing and remove when not. That way it is not visible. I know that is hard to picture by my explanation..
Don Hardman
1976 31' Sovereign
Old 11-10-2013, 09:01 PM   #93
okotoks , Alberta
Does it block a path from TV tires totally? Looks like it does but had to tell How long have you owned? Do you have shots of it on your setup?
In my opinion , it's the best mud flaps on the market , my second set , I have used them for the last 3 years , I have a few jet boats and they work , worth the money Pharm
dutchie is offline   Reply With Quote
Old 11-10-2013, 10:44 PM   #94
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by ROBERTSUNRUS View Post
Hi, you are going to get dings no matter what you do unless you just park your trailer. I put mud flaps on my Lincoln and bubble wrapped the entire front of my trailer for my Alaska trip. My segment protectors are dinged, my rock guard got a spider crack in it, and rocks got past the mud flaps and stuck into the bubble wrap. [new dings everywhere] It's going to happen; I only recommend that you wait a few years before you take your new tow vehicle and new trailer to Alaska, but you still need to do it. [bucket list]
Also my freshly repainted tongue and hitch got gravel blasted.
Hi, here are a few pictures showing my home made mud flaps and my bubble wrap job for my Alaska trip.
ID:	199721   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-11-2013, 12:57 AM   #95
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I am going to need a materials list And basic instructions on this DIY small project
Old 11-11-2013, 07:15 AM   #96
28Argosy's Avatar
1976 Argosy 28
Marshall , Virginia
Love this! My husband was commenting about need flaps and some kind of protection on the AS with the front glass recently.
1976 Argosy 28'
28Argosy is offline   Reply With Quote
Old 11-21-2017, 08:56 PM   #97
1965 26' Overlander
Medford , Oregon
Take a look at the DuraFlap site for the Black Friday weekend. A different sale every day.
They sell the mud flaps that fit the fender well of the truck. They are wide and long enough to fully protect your trailer, and they have the added protection for your truck fenders.
DuraFlap is offline   Reply With Quote
Old 11-21-2017, 09:55 PM   #98
Mollysdad's Avatar
Originally Posted by Splitrock View Post
My receiver on my 2000 Yukon XL only has about 1/2" of flat shank exposed between the buildup on the tube end and the welded mounting bracket on the top.
Attachment 127819
Anyone know if a clamp on Rock Tamer will work?
The Rock Tamers attach to the hitch shank and not the receiver. In other words, If you pull the hitch off, the Rock Tamers come with it.
mud flaps
Rock Tamers Mud Flap System au_ee Tow Vehicles 42 10-28-2016 06:50 AM
Mud Flaps?? 10Smiles Tires 14 01-27-2012 05:25 PM
Mud Flap question- pappy19 Rock Guards, Segment & Window Protectors 0 08-17-2011 07:59 PM
Home made mud flaps. ROBERTSUNRUS Tow Vehicles 14 07-12-2011 10:58 PM
