Old 03-20-2007, 04:13 PM   #1
Del317's Avatar
1999 19' Bambi
Arlington , Texas
Gravel Guard Problems
Has anyone had gravel guard problems. I have a 19 ft. Bambi with the driver side gravel guard that doesn't want to stay on. It was repaired once, by an experienced Airstream person, but came off again. I think the 18 wheelers passing by has some effects on the damage, but I wanted to throw out the question prior to me reinventing the Gravel Guard. Any ideas? Thanks.
Del317 is offline   Reply With Quote
Old 03-20-2007, 04:24 PM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
guard..
Does it have the center support at the top of the guard? This was a common problem and Airstream fixed the problem by adding a top support in the curve of the stainless/steel segment protector.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 03-20-2007, 04:38 PM   #3
Get the running gear properly balanced and/or reduce the rating of your hitch bars, and/or reduce or eliminate over load springs.
Those things cause vibration, which make the segment protectors come loose.
Old 03-20-2007, 05:48 PM   #4
Dwight's Avatar
1999 34' Excella
Joshua , Texas
rock guard...
This is a thread regarding the same problem.
http://www.airforums.com/forum...ure-21006.html
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Looking for a stone guard -1976 Argosy James Martin Rock Guards, Segment & Window Protectors 5 11-28-2005 07:49 PM
Lower Stone Guard Repair cesurman Rock Guards, Segment & Window Protectors 1 08-15-2002 07:22 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Stone Guard/ Keep it or Remove it? 74Tradewind Rock Guards, Segment & Window Protectors 9 06-26-2002 01:09 PM
