Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 01-06-2009, 04:45 PM   #1
Profile:  1976 21' Globetrotter
chanhassen , Minnesota
Glass Color, Screens and Vinyl
Happy New Year,
I'm in the process of re-furbishing my '76 Globetrotter 21'
The previous owner put laminated glass on the front window because he apparently had a rock break the front window before he bought the rock shield, which I have.
My question is - What color glass did airstream use in the 70's? I want to replace the laminated glass that has clouded up (I live in MN land of extreme temperatures). I plan on using 3/16" or 1/4" thickness. Also, where can I get vinyl U channel to surround the glass before putting back in the frame?
I'm re-screening - thought I read solar gray is the color of choice - is there any special mesh?
Thanks in advance!
Lastly, where can I purchase the thin spline that holds the screen in the groove of the screen?
kentuvman is offline   Reply With Quote
Old 01-06-2009, 04:47 PM   #2
P.s.
I plan to use tempered glass - don't like the fact that Lexan will scratch, being a former glazier at one time of my working life.
Old 01-06-2009, 05:49 PM   #3
Profile:  1973 27' Overlander
Space Coast , FL
Just rescreened all my windows in the '73 Overlander. I used the grey fiberglass screen rather than the charcoal color. I read a couple posts suggesting the charcoal darkened the interior some. Not that I couldn't use some dimming of the FL sun, but ...... thought the grey would complement the aluminum???? I got spline at the same place that I purchased the screen --- ACE hardware. I took a piece of old spline - that was degraded some and didn't hold tight (white, smooth). ACE gave me the smallest spline they had - grey and ribbed. It worked perfect. Nice tight screens!!! I really wanted screen that is No-see-um proof but I heard that the stuff sold as such is really very tight and it too limits sunlight. ?????
Good luck. It took me about 2 hrs to do the full trailer - well, except the door. I ran out of spline.....
funkill is offline   Reply With Quote
Old 01-06-2009, 07:50 PM   #4
Commercial Vendor
Profile:  Corona , California
Originally Posted by kentuvman View Post
Happy New Year,
Thanks in advance!
The front window on your Airstream could have been clear, or solar gray.
The gasket is not available.
New windows are available.
To try and use any more than 1/8 inch glass in the same window frame, and to have it fit correctly, I don't believe can be done because of the frame extrusion, that Airstream uses.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 01-06-2009, 09:42 PM   #5
Hi Andy and thanks for your reply.
The thickness of the laminated glass that came out of the front window channel is 3/16" thickness.
Solar gray sounds like a winner.
Old 01-06-2009, 09:43 PM   #6
Trimming the Screen
Did you use a single edge razor blade to trim away the excess?
Need Help cleaning our screens and vent screens ctalley316 Full-Timing 3 09-19-2008 12:48 PM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 04:38 PM
Argosy screens misterbee All Argosy Trailers 17 08-03-2006 06:14 PM
corian color preferences and vinyl floor choices? 2airishuman General Interior Topics 9 02-28-2005 07:57 PM
changing screens Perry Windows & Screens 5 02-22-2003 03:20 AM
