Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 01-26-2006, 05:57 PM   #1
highmark
highmark's Avatar
Profile:  1977 24' Argosy 24
Swan Lake , Montana
Question Front Window Cover
Hi! I am looking for any information on a cover for the front windows of my newly purchased 1977 Argosy 24' trailer. The curved windows in the front are original and in excellent shape. Living and driving in Montana is hard on windows. Would almost bet that I get a chip, crack or broken window the first time out this summer.....they sand the roads with gravel!!!. I am looking for the awning type that I think is made with an aluminum frame that lowers over the windows when towing and raises up when camped. Any help would be greatly appreciated. Thanks - Carol
highmark is offline   Reply With Quote
Old 01-26-2006, 07:00 PM   #2
65CV
Profile:  1965 17' Caravel
Southern , Connecticut
rock guard thread
Carol-
There is a thread called "Rock Guard Replacement" that should be helpful. The search function at the top of the page should lead you right to it.
63GT
65CV is offline   Reply With Quote
Old 01-26-2006, 07:37 PM   #3
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Front Window Cover
Greetings Carol!
Welcome to the world of Vintage Argosy ownership!
What you are looking for is commonly referred to as a rock guard, and assuming that your Argosy 24 is not an early Argosy Minuet 7.3 Metre, your coach will need the same three-piece rock guard utilized by the pre-wide-body Airstreams. Any Airstream dealer or Airstream Service Center should be able to order one for you. If your coach happens to be a Minuet 7.3 Metre, the same part will be needed, only the center section will need to be narrowed by about 8" to reflect the reduction of width found in the Minuets (the Minuets have a floor width of 7' while the Argosy standard series coaches have a floor width of 7' 8"). The rock guard was one of my first additions after purchasing my Minuet about three years ago.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 01-30-2006, 10:15 AM   #4
highmark
highmark's Avatar
Swan Lake , Montana
Thanks to Overlander64 and 63GT! I will check the thread suggested and get in touch with my nearest Airstream dealer. I wasn't sure if the rock guard was something from Airstream or an after-market. Thanks again for such a speedy reply. I can't wait for the snow to melt and get this project "on the road". Carol
1974 excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 02:53 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 10:13 PM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 12:01 PM
1974 Argosy- need front window dootsie Windows & Screens 1 10-21-2002 09:57 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 07:04 PM
test
