Old 08-25-2014, 07:19 AM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Question Fixing a DIY disaster on my Rock Guards.
So we just picked up our Airstream this weekend. And one of the things bugging me is whatever the previous owner thought they where doing on the front Rock Guards.
We all know what they are suppose to look like:
But mine, don't look like that. They look like this:
And now I realize I should of taken some close ups before putting the Airstream away for storage.
It seems they've been spray painted with some sort of DIY bed liner. When the sun hits these, the spray paint pattern is really obvious. I also noticed they are cracking along the bottoms and top edges and whatever is on it is peeling off. It looked like it might still be the original metal under neath. I'm hoping that's the case.
Has anyone ever seen someone do this, or know why?
BTW, I am the 3rd owner of this Airstream, the guy we bought it from bought it from the original owner in Feb and hit hard times. And I am assuming that it was the original owner who did this "mod". I should of asked, but was to busy being excited.
Anyways, rather than sell out $800 bucks buying new ones, was wondering if anyone had any ideas? I guess I'll try stripper first.
I just want things to match on my Airstream.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-25-2014, 08:47 AM   #2
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
In my case I am the 4th owner.
My rock guards were a bit pitted and I did not like the look so
I painted them with black bed liner. Same for bumper and a few
other mis-matching colors as you may see.
Del Gurney is offline   Reply With Quote
Old 08-25-2014, 08:52 AM   #3
2009 28' International
Columbia , Illinois
I actually quite like the look of that
sinjin is offline   Reply With Quote
Old 08-25-2014, 08:53 AM   #4
1981 31' Excella II
New Market , Alabama
Nothing wrong with painting them but that gray stuff does not look good at all. You can try stripper on them and see what the metal underneath looks like. Also the one on the passenger side looks like it is sagging. Alternatively you would skin them with aluminum or stainless over what is there. Thinner material will tend to dent more than the thicker guard material.
Perry
Old 08-25-2014, 09:31 AM   #5
Wayward's Avatar
Cary , North Carolina
Once you have the gunk off, have you considered a stainless-look PVC film - like people put on appliances?
So long you trim it right at the edge of the panels and re-cover the exposed edges with the molding, the adhesive should stay stuck.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 08-25-2014, 09:37 AM   #6
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I'm guessing there is some logical reason that the PO painted them...pitting, perhaps. You can spend the time and energy stripping them, to find that they don't look good...and end up repainting them. Or you can just repaint them to your liking and be done with it. Or you could rebuild them.
arktos55343 is offline   Reply With Quote
Old 08-25-2014, 10:27 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Tape off for recoat. Stencils for your initials, coat in contrasting color! Remove tape.
Ok, that was fun,,,
Oh, you could use Duplicolor REMOVABLE paint and change it when bored.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-26-2014, 07:04 AM   #8
1981 31' Excella II
You can get that bed liner stuff in custom colors and the commercial coatings are better than the DIY stuff in a can. You could make them match the colors of your favorite football team like they do here in the south or something else just as tacky. Personally, I would go for black like Del did above.
Perry
Old 08-26-2014, 08:08 AM   #9
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
If you do strip them be sure to remove them from the trailer, or at least protect everything around them. No reason to mess up anything else trying to fix this issue. I haven't done this, but other things I wish I hadn't.
BeachHouse is offline   Reply With Quote
Old 08-26-2014, 08:12 AM   #10
Nomadic , USA
Oh I will be. I have a massive shop which I stored the Airstream in. Lots of room to remove and work.
Old 08-28-2014, 12:48 PM   #11
Nomadic , USA
A few better shots.
ID:	220072   Click image for larger version
ID:	220074   Click image for larger version
Old 08-28-2014, 12:53 PM   #12
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Funny....I drove through the west coast of Michigan yesterday and across the Mighty Mac into the UP where I am currently ensconced just north of Channing. As I came up the roads department was painting the white fog lines north of Traverse City. When I pulled in last night I discovered my curbside rock guard was now white as was everything else curbside. Two hours of a pressure washer and a putty knife removed most of the paint, but the underside is still white and the lexan windows still have white spots...not a fun day....
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 08-28-2014, 02:59 PM   #13
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
Stainless Steel refinish
Too bad about the white paint, photobum. I got that on the underside of a '64 Impala and the wheel wells are probably still white today.
The rock shields are stainless steel with a brushed finish. It is very durable but can be scratched by rocks, abrasive cleaners and anything harder than itself. It is almost impossible to restore the brushed finish once it is messed up. That explains the painted DeLoreans you occasionally see. Whatever damage is under that textured paint is probably permanent. You may as well just repaint the rock guards, or else replace them. Some surface prep and new paint might look good.
Aironius is offline   Reply With Quote
Old 08-28-2014, 03:27 PM   #14
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Refinishing Stainless steel Rock Guards
Actually you can refinish the stainless steel. I've done it. What you do depends on how bad the dings and scratches are. Here are just two of the many "How To" videos on the web:
Small scratches:
Worse scratches and dings:
The Ice Man is offline   Reply With Quote
Where to get rock guards? Nicksut Rock Guards, Segment & Window Protectors 3 09-23-2004 11:27 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
rock guards segment protectors joecj76 Rock Guards, Segment & Window Protectors 21 07-02-2003 10:54 AM
Walbernized the rock guards and... Kistler Our Community 12 03-10-2003 07:12 AM
