Old 12-02-2014, 01:40 PM   #21
Storm Master
Ampman's Avatar
2005 25' Classic
Replaced both of my segment protectors this past summer. Thousands of tiny dents in them. I just took each one off and drilled out all of the rivets to release the sheet from its frame. Laid perfectly flat once removed from the frame. Purchased the exact match 304 stainless sheet cut to a rectangle about one inch bigger than the old ones. Used the old ones as a pattern and cut out using air nibbler. Put back together with rivets and remounted. Looks brand new. Cost about $90 and took me four hours total. I added rock tamers to the truck before I traveled again. Very happy with the outcome. Ampman.
Ampman is offline   Reply With Quote
Old 12-02-2014, 01:47 PM   #22
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I would definitely be more concerned with the compromised banana wrap than the rock guard. A hole like that will let a lot of water in which will damage your insulation and possible your floors. Not to mention providing easy access for rodents and snakes. I'd live with the rock guard and consider that a part of your Airstream's personality. But the banana wrap needs to be replaced ASAP.
Bob Martel
WBCCI# 5766
Old 12-02-2014, 02:19 PM   #23
Storm Master
Ampman's Avatar
2005 25' Classic
Smile
Just saw the second photo. Patch it up until you decide which way you want to go. DYI or have a pro do it. Many great options already discussed here. Temporary repairs will give you experiance and confidence for when you have future incidents out on the road far from home.
Old 12-02-2014, 04:00 PM   #24
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
The only AS I have ever seen without a dent, ding, pimple or a dimple was on the showroom floor.
NavyCorpsman is offline   Reply With Quote
Old 12-02-2014, 04:11 PM   #25
Miami , Florida
Wow. I am, once again, glad that I keep an eye on this forum. My rock guard sustained similar damage from road debris and I've been wondering if I should take the Safari to a restorer or the factory. I'll be removing it and heading to a body shop...
Patricia720 is offline   Reply With Quote
Old 12-02-2014, 06:22 PM   #26
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sometimes a simple fix will get you by.
This is "duct tape" zone!!!!
Tape horizontal from bottom UP. Keep lower edge of tape overlapping the previous course. Only tape up enough to seal the area.
Gorilla tape is 500 MPH stuff.. Get a cheaper one. Waxing the area where applying tape beforehand may help protect from the tape glue.
With the weather forecast the next few days you should handle soon.
Peace and Blessings..
Channing
WBCCI# 30676
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 08:32 AM
Rock Guard Advice GLovedahl All Argosy Trailers 5 10-23-2013 09:29 PM
How much should a new rock guard cost? jpfurber 2005 and newer - Bambi all models 8 09-28-2012 09:57 AM
Estimate for exterior injury khaines Repairing/Replacing Floor &/or Frame 2 03-14-2009 03:18 PM
Need help on getting damage estimate Zmod Insurance & Claims 7 07-11-2006 01:07 AM
